Results 1 to 10 of 10
Thread: 07 lsv surf wave help
07-16-2017, 04:59 PM #1
Where ru you riding ?? Sylvan Lake ?? I'm at Gleniffer all the time ... but I have an 08 LSV .. I have 650 IBS, 400 ski locker and 750 each back locker .. also suck gate below the LSV logo and I get this waveIMG_2792.jpg
2008 Moomba LSV, Gravity III, 1100 port.750 in goofy side rear,400 center,650 IBS everything else stock.....Home lake... Glennifer Lake, Alberta Canada...
07-17-2017, 09:36 AM #2
I would definitely try to adjust the angle on your gate, I've got mine at about 60-70 degrees and it never comes off. You'll probably want more weight or passengers up front also. I run 1100's in the rear (surf side full, non surf 50%) and center locker full (I think 400 lbs) + a sumo 540 bag on the floor up front.surfwave.jpg
2011 Mobius LSV
2005 Mobius LS (sold)
07-17-2017, 10:10 AM #3
Not to assume anything, you know the sukg8 goes on the opposite side of the boat than you are surfing, right? Also, what is your speed? Should be about 10.3 to 10.8 or so. The LSV loves weight up front. If you are not using the gate it has to be listed hard to the surf side to get a decent wave. With the gate, keep the 400 off side weight. Without it, either move the 400 up front to the walkway or just empty it.
07-17-2017, 01:03 PM #4
You definitely need some weight up front. Try moving you dad to the bow of the boat right in front of the driver's seat. This will keep his weight on the surf side but also lengthen the surf wave by having some weight on the nose of the boat. One of the best things I have done for my surf wave was to add the Sumo 750 lb IBS. As for you suck8, I have the COSMO suction cups and have not had them come off once but I also have just a little bit less than a 90 degree angle on it. Finally, the more weight you can the better you will be. If you cannot add ballast, add as many people to the boat as possible and have most of them sit on the surf side.
twkoehn
1100s in rear lockers
750 lb IBS
Acme 1847
