    Sep 2011
    Default 2000 Moomba Outback LS Oil Pressure
    Having issues with high pressure (15 psi with key on but engine not running, 50 psi at idle, and 75-80 psi at full throttle) on a 5.7 Indmar with about 300 hrs. The idle and throttle psi's were with warm engine (160 F). Running Mobil 1 filter and Rotella 15W40 oil (yes, the diesel version). Changed sending unit (both old and new were 240 ohm without engine running, but changing was the easiest/quickest resolution attempt) and still have same issue.
    1. Should the dashboard gauge read 15 psi without it being turned over? This is the case even with the oil cap and dip stick removed. If the gauge
    should read 0 psi when gauges on but engine not, can the gauge be reset/fixed?
    2. What should I look at next?
    3. Should I even be concerned? Lots of forum chatter regarding concerns with low pressure, but not many seem to be overly concerned with high
    pressure.
    Appreciate everyone's review/feedback.
    Jan 2019
    Lake Tahoe - 6200 feet elevation
    Ironically sort of dealing with that same question right now also. When I drained / changed the oil, I fill it up 75% and then top it off when its totally level / in the water. My concern is when I change it I dont get it all out and then ultimately Im worried about it being overfull. On my gauge when Im up to speed mine reads 70-ish PSI at anything above 25mph and then at idle it bounces around 40-50PSI.
    Im not as concerned with that gauge as I am with what it reads on the dip stick and boat level. My dipstick oil level is towards the top 90% ish full on that metal gauge.
    Adding boat is a 2008 OBV.
    Sep 2011
    I change oil in fall and top off after engine warms up in spring. Adding really didn't affect pressure much on dashboard gauge. Interested though if your gauge reads any psi with key on but engine off.
    Jan 2019
    Im pretty sure it reads zero when everything is off.
    Apr 2012
    Wake Forest, NC
    When the engine is NOT running the gauge should read zero. If you turn the key to “on” and it jumps up to 15psi without starting the engine, then it’s either the gauge, sender, or wiring. Since you’ve replaced the sender with no change I’d look at the wiring and/or gauge if you really want to correct it.
    In all honesty I don’t think it’s a big deal though. If you make 15psi the new 0psi, then all your readings look fine. 50psi becomes 35psi, 75psi becomes 60psi, etc.
    2018 Murder Max
    Jan 2021
    Columbus, Ohio
    The gauge is getting additional voltage from somewhere and it is making the pressure read 15psi. Once the sensor sends the actual voltage it is additive and looks high. Check the wiring in the dash on the gauges.
    I would bet there are several loose nuts on the back of the gauges and grounds and you are getting a false reading.
    If the oil level is right and you aren't blowing oil out in the engine compartment and there is not oil in the water then you are fine.
    2015 Moomba Mojo Surf Edition - SOLD
    4,000lbs
    Manual Flow
    2025 Mojo - Incoming
    Apr 2012
    Wake Forest, NC
    Yep, I was thinking grounds as well
    2018 Murder Max
