Results 1 to 10 of 16
    Jan 2021
    Columbus, Ohio
    The pump has to draw water through the v-drive first. It takes a minute before coming out of the exhaust.
    Are youbgetting water in the bilge? Missing or loose plug would cause some issues also.
    2015 Moomba Mojo Surf Edition
    4,000lbs
    Manual Flow
    Got it. I was hoping the water pressure from the garden hose (using a fake a lake) would push water through the system and come out of the pump housing since I had pulled the cover and impeller. Instead, the water was just spraying along the bottom of the hull where the fake a lake meets the hull. I didn't see any water in the bilge area.
    Ideas on the next steps? Start pulling hoses to see what I find?
    Where does the heat exchanger fall into the mix? I assume it's also cooling oil so I would need to make sure I am pulling the correct hoses.
    2017 Moomba Mondo Surf Edition
    Sep 2005
    Claytor Lake, VA
    Follow the large hose leaving the V-drive and the next thing it connects is the transmission heat exchanger. Pull the hose off and use your finger to clean out any debris.
    2005 Mobius LSV
    325 EFI
