Results 1 to 8 of 8
    Default Improved Oil Change for 2016 Craz 400 Raptor Engine
    For you folks doing your own oil changes I had an epiphany today! I have done my oil changes since new with a West Marine suction pump and a thin tube in the dipstick hole. I was careful to make sure the tube bottomed out in the dipstick tube. I was able to suck out 6 qts. of oil. As I read around this forum others were claiming capacity was 8 qts. I wish I could give the fella credit who posted this on this forum, I could not find the original thread. I routed the factory oil drain tube through the rear transom drain hole. A 1/4” female air hose fitting thread right onto the factory oil drain hose, after you remove the cap. One of the tubes provided with my Marine West suction pump fits right over the nipple on the air hose fitting. I pumped up my suction device and WOW, the oil came out in no time, MUCH quicker than the dipstick method. More importantly I got 8 qts out! Had to stop at 6, the capacity of my pump, dump it, and reconnect to get the last 2 qts out. It actually looked like 7 3/4 qts, but with replacing the filter I figure 8 qts is about right. So for 7 winterizations I have been removing 6 of 8 qts! At least I got 3/4 of the old oil out. But getting 8 feels great! I wish I could give the guy that posted this idea credit but as much as I appreciate this forum the organization lacks.
    Thanks tylerrnemt ! I finally found his post, wanted to give him credit!
    Salt Lake City, Utah
    Just a bit of advice.....don't put a suction tube down the dip stick tube!!!! I did it years ago and somehow the suction tube got caught and I was not able to get it out. It can get caught on a "lip or ledge" at the bottom I guess.
    https://forum.moomba.com/showthread....-dipstick-tube
    Since then, I run the engine for a minute to get the oil warm, run the factory drain hose out the back of the boat, hook up a small pump to my drill and attach the hose from the drill pump to the factory hose. Turn on the drill and the oil gets suction out in a minute or two. Very easy.
    Scott
    2021 Craz
    1997 Sea Ray 190
    Feb 2018
    Boating on Lake Martin, AL
    I saw that method on a video a few years back. I think it was wake man video when he had a Malibu with raptor engine. I like that idea better than suction dipstick method. Good post!
    2019 Moomba Max "MOOMBAE"
    2016 Yamaha AR192 - sold
    Apr 2013
    Knoxville TN
    I was never a fan of the dip stick approach.
    Bought a 12v sprayer pump and mounted it on a bucket that is big enough to hold all the oil.
    2018 Supra SL400
    I prefer the method I described above for 2 reasons. It’s quick and drains the full capacity. I have used the dipstick tube method on my last two boats and my Jet skis and never had a problem (except it’s SLOW). Not sure how people are getting the tube stuck?
    Jan 2021
    Columbus, Ohio
    I have been doing the 1/4" air fitting method since I bought my Mojo. I use an manual pump oil extractor that holds 9.5qts. I run the boat to temp, open the fill port and pull the dipstick to allow air in the engine, and pump the extractor. Works like a charm.
    I have a spin on Filter verses the new cartridge style. For this I use aluminum foil liners from treager grill catch can. It fits over the Filter with room to spare and bend to get in position. Spin the Filter off, catch it in the foil liner, catch any oil, wipe the surface clean and no oil in the bilge. The filter being gone gives easy access to the exchanger drain plug also.
    2015 Moomba Mojo Surf Edition
    4,000lbs
    Manual Flow
    May 2018
    OP,
    Glad you figured this out, the raptor drain hose is awesome combined with the extractor pump.
    Warm oil is key and using just gravity method is far too slow.
    2021 Supra SA 400
    2018 Supra SA 400 (SOLD)
    Michigan
