Results 1 to 10 of 12
    Jun 2013
    Default Ballast spring a leak at the fill fitting
    My 900# rear locker sac sprung a leak right around the fill fitting - the bag opening just separated from the fitting……anybody have any luck repairing these? If so, what did you use?
    Mike
    2013 Outback V
    - FAE
    - DIY suckgate
    Jun 2020
    Utah
    I had that happen last year. Tried three different things and while they all helped a little, none was entirely successful. I wound up buying a new bag. I think to be successful, you need to be able to weld PVC.
    2016 Moomba Mojo Surf Edition
    2000 Sharpe Houseboat 70x16 (Lives at Lake Powell)
    Mar 2021
    South Georgia
    I have never really looked at one that closely to be honest. Is that a threaded fitting that has a flanged nut inside the bag that compressed onto the pvc when tightened by any chance?
    2021 Moomba Makai
    Jun 2020
    Utah
    No. It is heat welded to a disc on the bottom of the fitting. The bag has a beaded lip that also sits in the fitting. If you bag is put in and loads on the fitting incorrectly, it will ruin the seal with the bag. The leak is relatively slow, but will fill your bilge.
    Jun 2013
    I got some JBWeld epoxy and we’ll see if that does anything.
    Mike
    2013 Outback V
    - FAE
    - DIY suckgate
    Mar 2021
    South Georgia
    If all else fails, flexseal tape! Lol!
    2021 Moomba Makai
    Jun 2013
    I was actually looking at the flexseal glue and may try that if the others don’t do the trick
    Mike
    2013 Outback V
    - FAE
    - DIY suckgate
    Apr 2013
    Knoxville TN
    Different folks have tried different methods. Some work on the temp basis: JB, 5200, new fitting glued from the inside and out. Best long-term solution if you do not want to keep messing with it - replace.
    Matt Brown (SC engineering) was posting on social media recently. Boat drivers are filling ballast bags and using the overflows to signal to the driver the "bags are full" is causing some of the blowout failures on boats.
    2018 Supra SL400
    Mar 2021
    South Georgia
    Quote Originally Posted by mikenehrkorn View Post
    I have not used the flexseal paste, but that tape does not play around. We have put it on some of our buildings gutters and it is still holding tight 4 years later with no deterioration. Crazy sticky!
    2021 Moomba Makai
    Jun 2020
    Utah
    Quote Originally Posted by MJHSupra View Post
    Like I said, that was my experience. I used 5200, river raft repair glue, I tried to temp repair with tear aid (worthless), I used the kit provided with the bags, everything outside of a PVC re-weld to make it like new...
    It won't work long term. The bag didn't cost enough for a replacement that I would consider it worth the time I put into it attempting to fix it.
