Results 1 to 8 of 8
Thread: Tower help
    Nov 2013
    Kansas City, MO
    Default Tower help
    Been a long time since I've posted! I've been using my boat in ignorant bliss and have mostly tapered off my upgrades.
    Unfortunately a couple weeks ago we had a a fire in our metal building. My 07 LSV took it hard. It was tarped which was the saving grace and all the damage was from smoke and soot. The soot is corrosive, as I found out later. Long story short, the tower and chrome bits (handles, cleats, window liner) are toast. The marina handling my insurance claim cannot locate a Rad a Cage 3rd gen.
    Has anyone put an aftermarket or newer Moomba tower on an LSV? Any pics, tips, tricks, sites, information you have would be appreciated! Or, I would also happily entertain a direct replacement.
    Thanks for your help y'all!
    2022 Mojo
    May 2018
    Default Tower help
    Rechroming an option or perhaps powder coating a complimentary color?
    2021 Supra SA 400
    2018 Supra SA 400 (SOLD)
    Michigan
    Aug 2021
    Knoxville
    I would have them quote the most expensive tower you can find. Then take your tower off for powder coating or polishing.
    2019 Craz
    OJ 950
    Wakemakers bags
    Heatercraft triple heater
    Nov 2013
    Kansas City, MO
    Thanks, those are good ideas. I had considered paint but disregarded it because paint usually doesn't stick well to aluminum. But powder coat is indeed better.
    2022 Mojo
    Jan 2021
    Columbus, Ohio
    You could have it anodized any color you want being aluminum.
    Cerakote would work also. It holds up on firearms, I'm sure it would hold up to your tower usage.
    If you can get enough out of them and then clean it up yourself, maybe add a bimini if you don't already have one.
    2015 Moomba Mojo Surf Edition
    4,000lbs
    Manual Flow
    Nov 2013
    Kansas City, MO
    Bimini was on there and is also destroyed. The smoke and soot really did a number. It permanently discolored and corroded any exposed metal in my barn including aluminum, galvanized and even stainless! My FAE is straw colored now! The fire put itself out and I kind of wish at this point it had completely burnt to the ground. It would have made life simpler in some regards.
    2022 Mojo
    Mar 2021
    South Georgia
    What was the material that was burning?
    2021 Moomba Makai
    Nov 2013
    Kansas City, MO
    Gasoline fueled trashcan fire. Started by an air compressor that melted down due to a faulty thermal switch and leaky regulator. There was all sorts of trash in the trashcan, metals, plastics, oiled rags, you name it.
    2022 Mojo
Tags for this Thread
