    Feb 2015
    Gardendale, AL
    Default Jabsco Ballast Puppy Reversible Pump
    Ayone ever rebuild one of these? One of mine is getting power but the shaft the green impeller is on is not spinning. I have removed it from the boat but haven't started taking it apart yet.
    Gil Hebert
    2014 Mojo
    May 2018
    Any debris blocking impeller? I would see if you can try and break it free with a pair of pliers.
    2021 Supra SA 400
    2018 Supra SA 400 (SOLD)
    Michigan
    Feb 2015
    Gardendale, AL
    The shaft spins by hand, just not when plugged in and getting power applied to it.
    Gil Hebert
    2014 Mojo
    Jan 2021
    Columbus, Ohio
    The windings are shot. Not worth rebuilding. New one is $200, and I never have seen a rebuild kit for the motor.
    2015 Moomba Mojo Surf Edition
    4,000lbs
    Manual Flow
    Feb 2015
    Gardendale, AL
    Where are they 200? I'm seeing 270 on wakemakers.
    https://www.wakemakers.com/products/...wakeboard-pump
    Gil Hebert
    2014 Mojo
    Feb 2015
    Gardendale, AL
    Gil Hebert
    2014 Mojo
    Jan 2021
    Columbus, Ohio
    Actually I am wrong here. The replacement pump is a Jabsco Puppy 18670 series - 8-9 GPM. They are $385 and discontinued.
    Wakemakers is selling you a 18220 series which is 9gpm at $250 and the replacement version.
    https://www.wakemakers.com/products/...BoCp3sQAvD_BwE
    $185 gets you the 18660 version which is 6.3gpm from the website below.
    https://www.hodgesmarine.com/jab1866...RoCQlUQAvD_BwE
    4,000lbs
    Manual Flow
