    Jun 2018
    Kuna, Idaho
    Default 2018 Max - water temp quite working
    Any one have issues with the water temp not working? Sensor? Also when surfing no mater the actual depth it shows water depth of 328 ft. if you stop to pick a rider up it will show the actual depth. Or without cruise one it shows the actual depth as your driving.
    2018 Max - Wetsounds - Wake Makers upgrade
    Jan 2021
    Columbus, Ohio
    More than likely....triducer starting to fail.
    2015 Moomba Mojo Surf Edition
    4,000lbs
    Manual Flow
    Jun 2018
    Kuna, Idaho
    Thanks, I will add that to the list for the dealer.
    Jun 2021
    Unplug it and plug it back in to see if that helps
    Jun 2018
    Kuna, Idaho
    Quote Originally Posted by gedakbx View Post
    Will do, thanks!
    Jun 2020
    Minnesota
    Where is the water temp on the screen?
    2021 Moomba Max 400
    Feb 2018
    Boating on Lake Martin, AL
    Quote Originally Posted by Precious Roy View Post
    In the user settings menu.
    2019 Moomba Max "MOOMBAE"
    2016 Yamaha AR192 - sold
