Results 11 to 20 of 22
Thread: Thru-Hull Drilling - Bit to use?
03-18-2011, 05:21 PM #11Senior Member
- Jan 2008
- Pensacola, FL
- 1,585
A standard hole saw has a drill bit on which you attach the hole saw teeth. The drill bit is used to center your hole, it also protudes further out than the saw. The drill bit will penetrate the inside surface well before the hole is complete. You simple go to the inside of the boat and place the drill bit in the hole and start sawing.
1997 MasterCraft 205
2008 Moomba Outback
1999 MasterCraft Sportstar OB
1992 MasterCraft 205
1999 Malibu Response LX
1987 Marlin Magnum Skier
03-18-2011, 05:53 PM #12
03-19-2011, 08:49 AM #13
Look in my upgraded thread listed in my sig if you want to see a 2 beer job to calm the nerves lol. The hole i put in the nose of my boat i could put my hand threw it. No going back when its that big.
[COLOR="#696969"]
04-02-2011, 06:16 PM #14
Do not use a regular hole saw. It will chip the gel coat. Goto Home Depot and get a 1" Diamond hole saw. It cuts like a hot knife through butter. I use this when I cut my holes for my new ballast system.
06-16-2011, 10:55 AM #15
bringing back old post.. Do you need to epoxy the hole or just use rubber gaskets to help seal the raw fiberglass
2009 Moomba LSV..Kenwood Head unit Kicker subs and 4 wet Sound tower speakers..3 kicker amps.. Green and Black ( green like the payments black like my eye when i brought it home ) lol J/K
06-16-2011, 11:03 AM #16
06-17-2011, 08:27 AM #17
ok so no need to seal hole with epoxy?
06-17-2011, 08:30 AM #18
06-17-2011, 09:12 AM #19
Don't really see a reason to use expoxy or sealant on the thru hulls, they don't do it at the mfg level. if you ever change them out it will be a B&tch to get them out using the 3m 4200 or 5200. MY .02 They shouled be well above the water line so splahing and rain water should not seep in.
06-17-2011, 09:46 AM #20
