Page 4 of 7 FirstFirst ... 23456 ... LastLast
Results 31 to 40 of 64
  1. #31
    Jul 2011
    Murrieta, CA
    Looks good. The 5200 is a good idea, wish I would have thought of that!
    You could always pull the screws and apply 5200. I hope I want it to be a permanent install because it is now that the 5200 is installed. LOL
  2. #32
    Jan 2015
    Live: OP, KS...Boat: Shell Knob, MO
    I installed a ladder on the Max for the in-laws. They struggle and even had someone slice their knee in the surf tabs while struggling to get on the platform.
    I used 1 1/4 inch stainless screws and 5200. Hope it holds and does not mess up my surf wave.
    Man oh man, please let us know how this works for you. I’d like to do the same if it doesn’t eff your wave and/or wakes up.
    2013 Mojo
  3. #33
    Apr 2013
    Knoxville TN
    Somebody on here mounted one on a newer SE. Reported no effect on wake or wave.
    2018 Supra SL400
  4. #34
    Quote Originally Posted by c h r i s View Post
    I have seen no adverse effects on the wave. Doesn't touch the water once you get around surf speed and higher. Just don't forget to put it up.
  5. #35
    Jul 2011
    Murrieta, CA
    Default Ladder for Moomba Max?
    No effect on the wave that I could notice.
  6. #36
    Mar 2020
    Old thread - I ordered one of the ladders off Amazon - only $55. Just confirming those that have installed the 1-1/4 long screws are fine to use? Just want to make sure they’re not too long.
    Anyone care to share diameter of drill bit used for pilot holes?
    I did buy some 5200 btw - nice touch for whoever thought of that
  7. #37
    Henderson, NV
    also following. what's the weight capacity of those and any issues with it pulling out? want to install but really don't want to thrubolt.
    will the 1 1/4 screws hold with a 250lb person trying to seal up on the platform?
  8. #38
    Jul 2011
    Murrieta, CA
    I have since traded the boat but with the screws and 5200 there was never any signs of movement. I believe the 5200 was giving as much if not more holding power than the screws.
  9. #39
    So far mine is still holding strong with just the screws and no 5200. We have probably had 250 lbers use it as well.
  10. #40
    Mar 2020
    Care to share what size drill bit you used to pre-drill the screw holes?
Tags for this Thread
