Results 1 to 10 of 23
Thread: Max wave stock ballast
06-04-2019, 12:40 PM #1
You would need AT LEAST 500lb of lead weight, but I don’t think that will even be enough for the Max. I would say 1000lbs would be ideal.
I have upgraded 1100’s in the rear of my Craz as well as the center tank, bow bag and 500lb of lead weight midship, and when I have 3 guys on the boat we also add 400lb bags across the back seat and one we switch to the side bench, depending on who’s surfing what side. 5 or more and we don’t need the extra bags.
Without the extra bags the wave is technically surfable but not all that fun for adult men, with a small crew.
Again comparing the Max to an old LSV is not fair. The buoyancy is WAAAAY more in the Max.
Craz holds 15 so it’s plenty big enough IMO.
06-04-2019, 03:45 PM #2Senior Member
- Jun 2016
- 288
My Max is not sorted yet. I have about 800lbs amidships per side. Its not even close to being enough for the max. My Max as it is with about 6+ people is pretty legit. I need to upgrade the rears to 1200s and add a bow bag.
I am going to borrow a buddies 900lbs sac and try a few different positions to gain some more data.
I finally read up on autowake,and will Play with that a little more too.2019 MAX
2001 Supra Sunsport SSV- SOLD
06-04-2019, 04:07 PM #3
06-04-2019, 04:15 PM #4
Pretty sure its the same Boatmate trailer for the Max and the SA. The SA weighs 1000 pounds more than the Max stock. So any added weight up to a reasonable amount should be fine. I have an extra 500 pounds in our SA with no issue. Just make sure it is spread out some.
2011 Sea-Doo Wake 155
06-04-2019, 07:40 PM #5
06-05-2019, 07:21 AM #6
So the weak link here is the tires? Trailer is rated to carry 7500 but with the small D rated 14" tires we shouldn't exceed 6100?
19 Max
Fully Exiled
