Results 11 to 20 of 40
    Here is a link that shows my setup: https://forum.moomba.com/showthread....6619#post96619
    I can do one half that good.
    I don't get it???
    David, any reason I can't extend the wires on my prosport 20 if i were to move a battery to the other side of the boat?
    ProSport says definitely 'NOT' in their manual. However, that is mostly for reasons of liability and not for any functional reason. I wouldn't have any issue with extending the wires to a smaller degree if you used the identical guage. But for a longer extension to the opposite side of the boat, personally I would re-locate the charger....because I do not know at what point the added resistance would influence the profiling of the dual batteries. If you have cut-in an AC inlet, I wouldn't hesitate to extend the 14/3 AC wire to anywhere in a towboat.
    I don't get it???
    It's making fun of one-upmanship. Get it now? It's actually a compliment with a bit of humor....but apparently a very small bit of humor....almost so small that it is completely undetectable.
    Well I don't want to relocate the charge because I don't want to move all of the batteries over, just one or two. Probably Just one
    Here's a link to mine, same boat as yours. I run three batteries and put the third one under the port bow seat. Everything is mounted forward of the fresh air bulkhead in order to maximize storage space in the cubby.
    https://forum.moomba.com/showthread....tereo+makeover
    Ha ha, well the first post may have gone over my head but this one made up for it. I always laugh loudest at my own jokes.
    I am trying eliminate that whole factory amp board on the port bow seat back. here is what i have now and it is a mess IMO
    did you trim the seat back amp board to give you more room?
    David,
    I prefer the charger on the front wall because you never have to mess with it, and if you do, it's four screws and a couple of quick disconnects, but nothing to adjust.
    Then I prefer the amplifiers lined up against the port hull. Easier to tune or access for diagnostics and service.
    Quality heavy gauge cable is very expensive for that amount of current without loss and for that distance. Also, you wouldn't want to double the length of the starter/alternator feed without stepping up the gauge. So in any scenario applied to this boat, I just don't feel good about splitting up the batteries.
