Results 1 to 10 of 12
    Default One off Custon Evolution Cover.
    Got my new cover in, took a few months to get it done as i wanted something speacial and there was some trouble getting it all done but i finally got it.
    First off this cover is simply amazing. If your even thinking about buying a New Boat, SC or who ever, and they want to charge you 600+ bucks for a cover, DONT DO IT get it deleted call Corey and for 900 you can get a true towing cover that will out last any factory cover out there.
    I will never own another cover for a boat again unless its by Evolution.
    The fit is perfect to the boat, the details under the cover are perfect, such as the rear of the cover rests on your rear deck, so theres a protective pad there to make sure your boat isnt damaged, and the cover isnt actually touching your fabric. The cover is held onto the baot at the rub rail with small clamps < not really a clamp but cant think of what you call it > and they are wraped with soft protective fabric. All the points on the cover that touch anything are reinforced, and paded as to not scratch the boat or cause any damage.
    At the tower legs, they use zippers, and these are heavy duty, also extra padding to protect your boat. There is a draw string simular to what factory covers have but the string is soft and pliable not hard and stiff. At each tower leg there is little latching hooks that allow to you undo the cord and fit it around the tower then latch it back together. This cord is whats used to sinch the cover down under the rub rail for towing.
    On the rear of the boat is 5 attachments, 2 go threw the rear D rings on the boat, and 3 are adjustable buckles that loop threw the rear handle on the boat. Then you have the draw sring that sinched the cover down at the rub rail.
    The cover isnt real heavy feeling but its a thick material.
    First time i put it on it was pretty stiff, i have installed and removed it 4 times, and its getting easier each time as the material is breaking in.
    Towing with this cover is awesome, you only get a little movement at the windshield and this is caused by the draft of the truck. No balloning, not flapping or anything.
    On to the pics.
    Cover installed.
    [COLOR="#696969"]
    Rear tower leg
    Front tower leg
    [COLOR="#696969"]
    I had some custom work on the cover done. I added some color matching stiching on the front and rear. You can see in the above posted picture of the rear of the boat, i also added Wake Makers and Exile logos.
    I have a swim deck cover being made as well, as soon as i get it ill post up on it.
    [COLOR="#696969"]
    Irondequoit Bay, NY
    i need a new cover too haha
    Rockford fasgate cabins
    Exile XM7's
    Exile Harpoon
    Polk 10in sub (2)
    Polk P330 amp (subs)
    Henderson, NV
    good looking cover mike. no excuses for you not to bring the boat over to boise for a weekend
    good time to promote exile audio...
    Portland Oregon
    That's sick, seems like I saw your boat at Exile/Wakemakers a few months ago. I was telling Spencer you had all the stainless gear on it I wanted (and tinted windshield). He said something like this guy upgraded everything, touche!
    -Jake
    Yea it most likley mine there, i was redoing the ballast system on it. i took out the airator style pumps and went with a 1inch lines and jabsco pumps.
    If you want to do the windhsield i can help you remove it and i know a guy who can do them. I do all my own work on my boat.
    Yea its generally at Wake Makers / Exile from Feb threw April doing upgrades lol.
    [COLOR="#696969"]
    Portland Oregon
    Sounds awesome! I should PM you about my neighbors x25, he put in all his digital kenwood amps out of his nautique and couldn't get the feedback out of the amps. Long story short he ended up at Kingpin and they are selling him all new amps. They gave him a choice between Exile and some European brand I can't remember. I referred to your boat and said EXILE!!! Maybe if I pm my number you can give me a quick call??
    -Jake
    Sweet upgrade!
    Aug 2009
    Montana
    If you do all your own work why is it at Wake Maker or Exile?
    sorry mike - couldn't resist!
    2015 "NOT A MOOMBA"
