Results 1 to 10 of 14
Thread: What size and style of anchors?
09-08-2009, 01:45 PM #1
Bought the Mobius XLV this past weekend and it didn't come with a Anchor so I was curious what style and size is everyone using. I'm planning on using 2 danforth anchors but not sure what size to get.
09-08-2009, 02:05 PM #2
Personally I am using a river/mud anchor-5pounds, a smaller danforth for upto 20ft boat, a large danforth for upto 30?ft, and have 1 sand spike, and 1 dog leash screw in the ground thing. Most of the time the smaller anchors work just fine. I only use that large anchor if we are camping and the boat is staying in the water overnight or its really windy out.
Hey, Its Moomba time
13 Mobius LSV-sold
08 Mobius LSV-sold
03 Mobius LSV-sold
09-08-2009, 02:17 PM #3
Using a box anchor. the smallest size they come in. Works well. Even when the wind is strong enough to flip it out of the ground, it almost immediately catches again by itself.
2007 LSV - All red
Wetsounds PRO 80's WS420 Eq
Acme 1433
09-08-2009, 03:33 PM #4
I use a 16lb. river for all situations and works well, but then we only ride on lakes.
Also i use an Anchor Buddy with it, makes shore anchoring much more easier. Anchor about 50' out with stern to shore. Stake out shoreline and pull boat in to load/unload and let it back out and tie off. Boat stays about 20' off shore and out of rocks and such.
Made my own shore stake by using a 24" steel rebar stake from Home Depot. Then cut a 26" length of schedule 40 pvc pipe, glued a pvc closed cap on one end for a stake case. Insert stake and slip another closed cap on the open end. That way i can carry it in the rear locker without worry. Picked a vinyl coated 2.5 lb sledge i carry also.2007 Mobius LSV
09-08-2009, 10:08 PM #5
clarkro2 - No anchor. Only once have I wished I had one, and that was so I could enjoy the pro wakeboard show at a Skier Choice jamboree summer of '08. We either run or sit on a lift, so an anchor presents no practical use. Also, it's just another thing taking up space. Our play environment on a small lake seems to differ from others on this board, so be sure to get the benefit of their experience. - Deerfield
2007 Outback - SOLD June 2016
2012 RAM Crew Cab
2015 Subaru Forester
Stuart
09-08-2009, 11:26 PM #6
I use a Danforth with a 4 foot chain and an anchor buddy I made myself along with the dog stake out. Last week at Lake Roosevelt there were no boats and the water was glass so I nosed onto the sand which I don't do often. Besides, the music is going the wrong way but I was too lazy to anchor out.
1998 Mobius
310 HP PCM
SOLD
09-10-2009, 11:55 AM #7Senior Member
- Feb 2005
- Ottawa, Ontario, Canada
- 718
If you have an engine failure and start drifting toward rocks or a cartoonishly large waterfall, an anchor will start to look pretty good. Besides, it's a bit more ballast!
I use a Danforth. I am not sure what its size or weight is, but it's the largest that had easy ingress and egress from the XLV's front right underseat storage. It holds reasonably well against the local lake's mostly muddy bottom. I also have a smaller Danforth from my previous boat as backup.
09-11-2009, 08:58 PM #8
Thanks for the responses. I went with a small box anchor since I'll be mostly using the boat in lakes. Also went with 4 feet of chain and 150 ft of rope. Will test it all out tomorrow on the lake. Have a nice weekend everyone.
09-11-2009, 09:37 PM #9
amen to that- perhaps it's the years experience as a kid boating on less reliable boats but I've always felt an anchor was a pretty important safety item. In the event of engine malfunction it's the first thing I reach for- buys time to collect thoughts especially if it's windy. Using a 12# river on my boat with 4 ft chain- so far has held in some pretty windy conditions.
2021 Malibu 23 LSV
2008 OBV-Sold!
2001 Ski Nautique closed bow-slalom course only!
attracted to shiny things that float
09-13-2009, 12:51 PM #10Senior Member
- Jun 2008
- Eugene OR
- 1,786
One thing about anchors is the area that you go and how the bottom of the lake is. I also have a box anchor and it works great for the river but most of my likes it sucks. This is becuase the ground is so hard because it drys in the winter it cannot dig in. My friend has a 30lb triangle anchor and it works great. The box anchor works great if it can dig in.
