    Jan 2009
    Calgary, Alberta
    Default Seat Repair / Upholstery
    Hello all. I have 2004 Moomba XLV and one seat section requires repair and a reupholster. The section is the one that converts to a rear viewing seat. I took it apart yesterday and found the base is some kind of aluminum honeycomb. Because that section is only supported on three sides, the ongoing wear and tear of people stepping in and out of the boat has bent the two concerns. I tried a local dealer to see if that seat was still available (long shot) and was told no. Has anyone encountered this or does anyone have any ideas for a work around?IMG_1147.jpgIMG_1149.jpg
    2004 XLV - 340 HP
    Mar 2021
    South Georgia
    Here is a cmpany that makes them. The panels that is. You might do an internet search and find some more. Or just use a thick piece of polyethylene panel and put an aluminum angle or steel c chanel under the unsupported edge for more rigidity.
    https://www.flatironpanelproducts.com/store.html
    2021 Moomba Makai
    Mar 2003
    Springfield Missouri
    Local upholsterer.
    1998 Mobius
    310 HP PCM
    SOLD
    Jan 2009
    Calgary, Alberta
    Thanks for the replies. There was an indentation on each side and I thought that was from factory. Probably the corners had already started to collapse when I bought it several years. I’ll try my local upholstery place first and then move to the other two options.
    2004 XLV - 340 HP
