    May 2018
    Default Add newer tower camera to 2018 SE
    Is it possible to update the tower camera on a 2018 SE 450 with the newer camera that is not as affected by the Bimini? I don’t know if it is possible or if you can even buy one. Thanks!
    May 2018
    Quote Originally Posted by cal1319 View Post
    The 2019+ fx one tower cameras have a spacer block that clears the Bimini, your dealer should be able to source the spacer for you.
    2021 Supra SA 400
    2018 Supra SA 400 (SOLD)
    Michigan
    May 2018
    Awesome… thank you for the reply. I will reach out to the dealer and see if they can help!
    Aug 2020
    Middle Tennessee
    Not really. Needs to be an inch or two higher IMO I still see the Bimini in the tower camera on my 2020
    2020 Supra SA
    May 2018
    Well right now with the Bimini is about 50% if the screen… if it’s better then that it might be worth while haha
    Mar 2021
    South Georgia
    Sounds like a job for someone with a 3d printer!
    2021 Moomba Makai
    May 2018
    I haven’t had a chance to dig into the tower camera yet but I gather it’s relatively easy to remove it? If so getting making a new mount might make sense
