Page 1 of 4 123 ... LastLast
Results 1 to 10 of 31
    Feb 2019
    Tulsa
    Default Adjusting rear sensors for larger bags.
    It’s frustrating to upgrade the bags only to fight with your boat to fill them.
    #1 you will need to upgrade / reinforce your engine panels. Perhaps even the rear access panels.
    #2 purchase 2 check valves 32003-100 from Wakemakers ($17 ea) and 6 hose clamps size 16.
    #3 you’ll need a heat gun. Everything else is done with basic tools.
    This process will net you 6” higher sensors and prevent air from entering your bags when you drain them.
    Remove both overflow assemblies. From the bags to the through hull fittings.
    ‘22 Makai
    '06 Gravity XLV -sold
    https://www.youtube.com/GreaseMonkeyTV
    Feb 2019
    Tulsa
    Cut the long hose about 14” from the straight fitting that connects to the top of the sensor.
    Remove the straight fitting from the short hose that went between the bag and the sensor. Use it on the 14” section pointed at.
    You will need to heat the hose to get it over the barb on the fitting.
    ‘22 Makai
    Feb 2019
    Tulsa
    Install the check valve between the end of the short hose and the rest of the long hose that goes to the through hull fitting. You’ll need to cut off the end that was pressed on the fitting.
    Make sure it lets air move the direction of the through hull end.
    ‘22 Makai
    Feb 2019
    Tulsa
    The finished assemblies will look like this.
    ‘22 Makai
    Feb 2019
    Tulsa
    When reinstalled, they will look something like this. Connect the bag first, then place everything else off to the side where there’s room for the 90° on top of the sensor to be touching the bottom side of your rear deck.
    ‘22 Makai
    Feb 2019
    Tulsa
    Finally, cut whatever extra you have from the long hose at the through hull fitting.
    Hose clamp was just draped over the fitting in this photo.
    ‘22 Makai
    Feb 2019
    Tulsa
    Here’s a before photo for comparison.
    ‘22 Makai
    May 2017
    Alberta, Canada
    Great guide Brent. This is the way.
    2021 Mojo, 6.2L Raptor 400/1.76, Acme 3407 15.5x13, G6, Flow3, +6500 lbs ballast
    2005 Mobius LSV (sold)
    Windermere Lake, B.C., 2800' Elevation
    2021 Mojo Mods
    Mar 2021
    South Georgia
    Brent, you are correct in your comment about reinforcing the rear, or what I call the stern, panel. The port side popped out on mine after putting in the WM upgrade. I have not addressed it yet. The only good thing is it can't move very far. But it can put pressure against the pumps and hoses that are behind it.
    2021 Moomba Makai
    Apr 2013
    Knoxville TN
    That is also some easy access to change any impellers.
    2018 Supra SL400
