Results 1 to 10 of 13
    Jun 2020
    Rockwall, TX
    Default White smoke at the 10hr mark
    I picked up my first Moomba on Thursday and around the 10hr mark some white smoke was noticed coming from under the water platform. At first I searched and thought it was just vapor from some forums, but now it's doing it consistently while cruising or surfing
    Coolant temp stays around 160-ish
    no smoke in the engine compartment
    engine runs good and no issues other than the smoke.
    Any ideas?
    Commerce Lake, MI
    Got video?
    Watch the coolant level.
    2017 Moomba Craz
    Apr 2013
    Knoxville TN
    Many people think the vapor from the exhaust is something along the lines of oil consumption.
    If you do not have a surf-pipe, once you start surfing you can smell fumes - it's normal.
    I would keep and eye on the oil and coolant levels (as Stazi mentioned). Many on here can help if you post that short video.
    2018 Supra SL400
    Jun 2020
    Rockwall, TX
    Got video?
    I'll get a video this afternoon and post it up- thanks
    Jun 2020
    Rockwall, TX
    the surf pipe isn't on this boat- my concern comes from the "smoke" coming out while cruising as well as surfing. Is that normal
    I plan on adding the surf pipe at my 20 hour service,
    the oil pressure and coolant temp are staying normal, I'll keep a close eye on the levels as well.
    May 2018
    I think what your seeing is simply exhaust coming out through the water. Byproduct of underwater exhaust.
    Put a surf pipe on it, if it was coolant it would smell sweet and likely billow in clouds.
    2021 Supra SA 400
    2018 Supra SA 400 (SOLD)
    Michigan
    Commerce Lake, MI
    Exactly my thought.
    2017 Moomba Craz
    May 2018
    The raw water cooling loop does discharge through your exhaust.
    You can get a lot of exhaust fumes at the back of boat, great idea to get the surf pipe.
    2021 Supra SA 400
    Michigan
    Jun 2020
    Rockwall, TX
    thanks everyone for the feedback and info. I'll keep tabs on the levels and as soon as they open in the morning I'll schedule for the surf-pipe install
    Jun 2020
    Rockwall, TX
    Here is the video from this evening after about an hour on the water
