Results 1 to 10 of 14
    Default Big guy surf help
    2018 craz with stock ballast, no autowake, Iíve searched the forums and tried a couple of things and still canít get ropeless, my wife 120 pounds lighter can and with ease but me or any of my friends who are all 200-250 range canít seem to feel any push until up on the swim deck, we are running 10.8 -11.3 mph and all bags full with surf plate at 65 and wakeplate at 25 which are the presets I believe, do I need to list the boat aggressively when I try to surf, any ideas would be much appreciated we have a hammer head and a doomswrll neo
    Jan 2017
    Try dropping your wake plate to 10 a few times and then to 0 a few times and give it go.
    2017 Moomba Craz Surf MAX Edition
    Flow 2.0 Surf System w/ AutoWakeô
    4,600 Lbs Ballast - Enzos + Lead
    Henderson, NV
    I spent some time on a craz back in '16 with factory bags and couldn't go wireless either.
    my opinion it needed a bunch more weight. wave had a decent shape with factory ballast but no push at all.
    Apr 2018
    Texas
    Iím 240 and couldnít go ropeless on the mojo until I added weight and lowered the speed stock ballast isnít going to cut it
    2015 Mojo
    2005 Yamaha at-230 sold
    2012 Ram 2500 tow rig
    So do I go with the enzos? And what about front weight
    Apr 2018
    Texas
    Quote Originally Posted by Sickpainter18 View Post
    Thereís been a lot of topics on the Enzoís if you search it. RZ is the man to talk about getting your craz wave dialed in. I have Enzoís only downside is lose of storage I also have 250lbs of lead in the nose including a 750 bag piggy backed off the hard tank makes for a nice long wave
    2015 Mojo
    Jan 2017
    Unless you roll with a huge crew on the daily....this is your Craz recipe for success.
    To start, identify your boating necessities and verify you can fit them within the Observer's compartment and the over engine tray. This is your viable storage space....learn it, live it, love it. If it don't fit, you don't need it.
    Get your Enzos for the back and in addition to your IBS, add 500lbs of lead to your bow under the bow cushion. This will help maintain pitch without AutoWake dumping your rear bags.
    Going to order the enzos tried the 10 and 0 wakeplate yesterday and it was a touch better but still not what I needed, and am also going to go for lead, where do you prefer buying the lead bags from and can you just leave them in the boat or do your place and remove each time
    Also Iíve tried playing with screen and reading manual, I donít have autowake any way to see pitch and roll without it?
    Jan 2017
    You can use your phone to get rough pitch & roll measurements .
