Results 1 to 6 of 6
    Oct 2016
    Wisconsin
    Default Question about surf tabs on my 2019
    So I am out breaking in my new boat, tried the surf left and surf right on the screen and everything works. When I get back I started cleaning my boat and noticed the starboard tab didn't retract all the way up. Surf was off on the screen but that tab was in a more slightly downward angle than port tab. Is this normal?
    2019 Mondo
    Nov 2008
    Did you flip it back to the middle? If you donít it will be like that when you trailer it. Ask me how I know.
    '19 MAX
    '13 Mobius LSV - Sold
    '05 Mobius LSV - Sold
    Oct 2016
    Wisconsin
    I don't think so. I just hit surf off on the screen. The middle between surf right/left
    2019 Mondo
    Apr 2012
    Wake Forest, NC
    Turn the battery switch off for a little while then back on, and then turn the key on. Should retract back up if itís not still in surf mode.
    2018 Murder Max
    Nov 2008
    Does the mondo have the toggle switch for surf left/right? If the toggle switch isnít back to the middle, when you are going slow speeds, your plates will be at those predefined setting, even if you arenít using autowake or anything else. The middle is for wakeboarding/cruising and moves the tabs back.
    '19 MAX
    Oct 2016
    Wisconsin
    i never used the toggle and believe its in the center. Only used the screen. I will try the battery switch.
    2019 Mondo
