Results 1 to 10 of 16
    Dec 2017
    Seattle, WA
    Default Supra SL Ballast pump location
    My left ballast pumps have slowed down and figured I’d pull the impellers. But I just realized I’m not sure where the pumps are. Before I start pulling panels can someone point me in the right direction?
    2018 Supra SL
    May 2018
    The rears should be accessible through the trap door under the flip seat, fronts are accessible through the round floor door next to drivers seat
    2021 Supra SA 400
    2018 Supra SA 400 (SOLD)
    Michigan
    Dec 2017
    Seattle, WA
    Cool thanks
    2018 Supra SL
    May 2018
    DFW, Texas
    i just noticed that my portside pumps take about a minute longer than the starboard side. Didn't happen last year. Did not think impellers would go bad in one season though. Is that somewhat normal?
    2018 Max - Ultrablue flake/Gray - 4400 lbs water (720s midship), 750 lbs lead somewhere
    Dec 2017
    Seattle, WA
    That’s the same thing I noticed, but it’s intermittent (sometimes 2-3 min longer). I’ll update after I swap the impellers.
    2018 Supra SL
    Apr 2013
    Knoxville TN
    What pumps do they use on the SL?
    When I did my upgrade from wakemakers, the pumps came with these black imps. They sucked, would get stuck after 1/2 season. So I switched them out, they make the orange and green ones, depending on the pump.
    That was years ago, I figure they would come with 'good' imps from the manf.
    2018 Supra SL400
    Nov 2016
    Knoxville, TN
    Mjh, Auto wake and g6 ballast wears out an impeller faster since in runs more... they are ballast puppies, green impeller.
    2011 Sea-Doo Wake 155
    May 2018
    Per the fill times on the 2018’s it appears the pumps might be kings on the SL.
    The ballast is the same as SA/SE but fill times are faster on the SL.
    2021 Supra SA 400
    Michigan
    Nov 2016
    Knoxville, TN
    Good catch... that's what I get for assuming, lol
    Nov 2016
    Knoxville, TN
    All new Supra and Moomba use ballast puppies....SE more ballast than the SL and SA... SA uses hard tanks and bags, whereas SL and SE uses just bags.
