Results 1 to 10 of 19
    Nov 2018
    Default Closed loop cooling
    Trying to see if anyone has done a closed loop cooling system on a 5.7 Indmar engine? If so who has a kit? 2004 moomba outback
    Oct 2010
    Lake Wylie NC Area
    Replace the manifolds, circ pump and a couple other monor parts and get another 15 seasons out of it for less then converting it.
    Aug 2011
    Commerce Lake, MI
    What a massive waste of money. As MLA said. Maintenance of your current setup is key. Save your money and buy a newer boat with closed loop cooling down the line. There is no point spending the money to convert a 2004 to closed loop. What’s the point?
    2017 Moomba Craz
    Nov 2018
    Better for the engine, closed loop is more efficient and less maintenance. I don’t mind the maintenance I’m just curious if anyone makes a kit. I don’t see how spending at least 40k on a boat with closed loop is the cheaper alternative to updating mine. If no one makes a kit that’s fine but I haven’t been able to locate one myself. My next choice is to build my own closed loop system.
    Oct 2010
    Lake Wylie NC Area
    As a 23 year boat owner and does his own work as well as professionally, you got my attention!
    May 2018
    If anyone makes a conversion kit, it would be the OEM of your engine.
    I would start by contacting https://www.skidim.com/departments.asp?dept=1003
    The only real advantage I would see is if you are running in saltwater.
    2021 Supra SA 400
    2018 Supra SA 400 (SOLD)
    Michigan
    Aug 2011
    LOL.. There's more maintenance with closed loop..
    2002 Moomba Mobius LSV - Sold
    2006 Moomba Mobius LSV - Sold
    Oct 2010
    Lake Wylie NC Area
    Quote Originally Posted by parrothd View Post
    Well, I have my opinion regarding winterizing and maintenance, but im genuinely curious in his opinion.
    Nov 2018
    I’m just here asking for a kit I didn’t want to start a debate on what is better. But I will say it’s obvious with a closed loop system the engine temps are regulated at better temps throughout all throttle settings. The better your engine temps are regulated the more efficient your motor is....that’s with every engine ever made that’s not secret. Internal corrosion is eliminated, and obviously ur always run non contaminated fluid through your engine. No chance of sand, grit or whatever else is being sucked in the engine from the lake. almost all new boats with inboard engine come closed loop so that alone should tell you what is better....I’m not here to question someone’s knowledge on this topic. But it seems that no one has a true answer.....they always say the same thing “ just replace this just replace that “.....clearly I know that is an option if i wanted to keep that same set up...I’m just simply asking if there is a kit or not. I don’t need the obvious “change this and that keep it the same” answer. I figured someone on here would maybe have some input on this topic. What’s the point of asking questions on a forum? If I wanted to keep my engine open loop I wouldn’t be here asking if there’s a kit. I don’t need to be told “just keep it the same”
    Nov 2018
    I appreciate it
