Page 1 of 5 123 ... LastLast
Results 1 to 10 of 47
    Nov 2014
    Default Underwater LED install
    So the wife got me the "loki" boat plug light that replaces the rear drain plug flange. The install looks easy enough, but does anyone have a suggestion about the wiring part of it? I thought I saw a post about the wiring already being installed and run to the transom in the newer boats. Can anyone fill me in on where to find the wire that I need to tap into? Thanks!
    Sent from my SM-G930W8 using Tapatalk
    2016 Craz.
    Enzo bags.
    Commerce Lake, MI
    Quote Originally Posted by mattsask View Post
    There’s a pig tail to the top and right of the transom, looking inside the engine bay, almost tucked behind the black trim piece that runs across the lip of the top deck of the hull. Just follow the hanging extraction hoses up from the exhaust pip and you will see it.
    2017 Moomba Craz
    Nov 2014
    You're the man, stazi! I have a couple other underwater LED lights that are on the weaker side. I might install them to run with the plug light. Can I tie those in with the boat plug light on the same wiring harness?
    2016 Craz.
    Enzo bags.
    Commerce Lake, MI
    Probably. All depends on how many amps your lights are pulling. Do you have the specs on them?
    2017 Moomba Craz
    Nov 2014
    I do, but I'll have to dig them out and get back to you.
    2016 Craz.
    Enzo bags.
    Nov 2016
    Knoxville, TN
    Matt, I have 2 sets of lights running off one switch. You may want to consider installing a fuseable link in line to the switch, otherwise you are relying on your switch breaker should anything bad happen.
    2011 Sea-Doo Wake 155
    May 2011
    Flower Mound, TX
    Wait..... so there are already wires ran for this???
    '08 Mobius LS. Sold
    '18 Craz "TypeO"
    REV10's, Revo6 xss, Kicker10, Kicker 12 CompR, various LED's
    Could be. In the past 7-10 years, we've seen more and more manufacturers move to a common wiring harness for all their builds. The harness is built with all the leads needed to service all or nearly all the options the manufacturer offers.
    Gone are the days of a base level harness and the assembly tech custom wiring portions of the boat for the added options. Its plug-n-play as the boat goes down the line. The extra materials used for the harness is offset in saved labor time.
    Commerce Lake, MI
    Yes, the wires are there on the latest Moomba models. And they are connected to one of the accessory switches on the dash
    2017 Moomba Craz
    May 2011
    Flower Mound, TX
    Man, so glad i read this!!! I have a dragon coming. Good stuff guys
    '08 Mobius LS. Sold
    '18 Craz "TypeO"
