Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
  1. #11
    Oct 2010
    Lake Wylie NC Area
    Quote Originally Posted by David Analog View Post
    So Phil, if I wire two AC light bulbs with one in reverse polarity will I have total darkness if I am standing an equal distance from both light bulbs?
    Half as bright due to phase cancellation
  2. #12
    Nov 2009
    Stillwater, Oklahoma
    What is out-of-phase when the load is a simple resistive wire anyway?????
    The wire in the bulb doesn't care... It's performance is not phase sensitive
  3. #13
    Quote Originally Posted by philwsailz View Post
    Hah!
    David...
    Certainly not using old incandescent bulbs. The light comes from a super-heated filament. The light comes from the bulb because the wire is hot. The glowing of the wire does not does not oscillate appreciably with the supply voltage because the heated filament does not change temp much between cycles. Besides, the 60-cycle AC current is so low relative to the wavelength of the light that it is irrelevant.
    Now as you move past the two bulbs you might experience some comb-filtering and interesting color effects, but the speed at which you moved past the two bulbs would be pretty darned fast. Like close to the speed of light. You would be really-really long, and time would go by real slow based on your perception of time at that speed...
    I was absolutely certain that you would know. I'm glad I asked.
  4. #14
    Aug 2009
    Montana
    Damn this thread is now interesting since the OP is gone! LOL
    2015 "NOT A MOOMBA"
    Why Not? Play Hard! Get wet
  5. #15
    Nov 2009
    I think you knew all along...
    Funny...
  6. #16
    Funny...
    Actually I was leading up to the multiple benefits of a strobe light.
  7. #17
    Arkansas
    You two are cute
    Sent from my XT1080 using Tapatalk
    2016 Moomba Mojo
    2006 Supra 24SSV - Traded
  8. #18
    Jun 2009
    Western KY
    You two are cute
    And old
  9. #19
    Lmaof. Button
    May 2015
    Woodlands/Conroe, TX area
    Default Finding Positive wire on Exile Speaker
    Good thing you didn't do it when someone was calling. The ring voltage on a phone line is 110...
    I actually believe the voltage is 51vdc when ringing. 5vdc not being used.
    2008 Moomba Outback DD resurrection
