Results 1 to 10 of 12
Thread: left side balast not filling
06-12-2012, 03:01 PM #1Junior Member
- Jun 2012
- Martin,TN
- 10
I have a 2010 LSV, last year first time out my front and goofy side bags would fill but not my port side. I was not sure what the issue was. I tore into the back of the boat to check impellar, it was fine then I poured water down that hose until I heard it run out of the bottom of the boat. So really I did nothing and it worked great the rest of the year. This year same thing happened, everything works except the port side. I have not worked on it yet but was wondering what is causing that and is there an easy fix? My dealor is 4 hours away so if there is something simple that I can do myself I want to do that first. This is my first v drive with sacks, I owned an I/O for 12 years before this one so I admit I have a little bit of a learning curve to go through.
06-12-2012, 04:12 PM #2Senior Member
- Jun 2008
- 143
99% sure its your solenoid operated valve which can be replaced for 13 bucks anywhere that sells irrigation supplies (Lowes). Search the board for more details or PM me if you have questions. It is a cheap and easy 10 minute replacement.
2022 Mojo
06-12-2012, 04:38 PM #3
06-12-2012, 10:02 PM #4Senior Member
- Jun 2008
- 143
Oops, sorry OP.
2022 Mojo
06-13-2012, 07:31 AM #5
06-13-2012, 07:38 AM #6
As to the original question, my first guess is the pump is not priming and/or just sucking air.
In your driveway, disconnect the port bag, get a bottle of water, turn port ballast switch to drain and pour the water into the quick connect end of the hose. This should get the pump primed and push the water out the bottom. I'm thinking once the impeller gets wet it should work better once you launch next time. Turn off switch and reconnect ballast bag
When you do launch get up to about 20-25 and hit the port ballast switch to Fill. Hopefully it will draw the water in and fill the bag as expected.
Edit: The hose you are interested in is the lower 1" hose. not the upper drain hoseKraig - 2010 Outback V
06-13-2012, 12:34 PM #7Junior Member
- Jun 2012
- Martin,TN
- 10
Kraig,
Thanks so much, I feel as you do about it being a priming issue but I just wonder why the other two bags are working fine right off the bat and this one does not.
I will do as you say and I hope that is the simple trick that I am looking for. Thanks so much for your reply!
06-14-2012, 07:24 AM #8
It is a good question I don't have an answer for. My center has been a weak link on mine, same issues as you have with it not priming easily and new for this year is it randomly not working. Sometimes it'll run (may or may not prime) other times it growls and quits then I get a two blink fault code, which eveidently means high amp draw which can mean any manner of things. Mine is acting like it has a flat spot on the windings. Did it to me again last night, so when I got home I hooked up my garden hose to an adapter I build to connect to the fill/drain line and turned on the garden hose. Then powered up the pump and is started working just fine. I guess the water pressure helped get the impeller spinning. Once it starts running it runs well, but the damn thing just won't start all the time. I think I'll have to pull the back locker panel and see what is going on with that pump...Kraig - 2010 Outback V
06-14-2012, 09:21 AM #9Junior Member
- Jun 2012
- Martin,TN
- 10
That sounds an awful lot like my issue just a different bag. I will most definately try pouring water in the lower hose. The pump runs and like I said has that 2 blink fault code. It makes perfect sense that I need to get water to the pump. I will know for sure on Saturday and I will be sure to let you know if it worked. Thanks so much.
S
06-18-2012, 12:01 PM #10Junior Member
- Jun 2012
- Martin,TN
- 10
Just wanted you to know that I did what you recomended and worked like a charm. So I guess I know what I will need to do from now on when I am getting the boat out for the first time every year. Thanks for the reccomendation.
S
