Results 1 to 10 of 10
    Dec 2003
    Seattle,Wash.
    Default What Synthetic Oil to Use
    What brand and weight of Synthetic Oil are you using in your Moomba.
    Thanks, Larry
    Ottawa, Ontario
    Royal Purple 15W40 with K&N Oil Filter
    2008 Outback V - gravity III ballasts, perfect pass star gazer, hydraulic wake plate, depth finder, water stainer, rad-a-cage tower, board racks, tower mirror, bimini top, audio package d, graphics package e, appearance package, cockpit & tonneau cover, mooring cover, black stainless rubrail, docking lights, OJ 14.25x14.0 prop.
    Jun 2010
    Lake Houston
    I use mobil 1 20W-50
    2013 LSV
    2005 LSV - SOLD
    Oct 2007
    Panama City Florida
    Quote Originally Posted by lewisb13 View Post
    Are you sure it isn't Mobil 1 15w-50 as that is what we been using. Great Stuff!
    May 2003
    south east michigan
    I use Royal Purple 15w40 with a Delco filter.
    jy
    Jun 2010
    Lake Houston
    Quote Originally Posted by zegm View Post
    Yeahhhh I think you might be right.
    2013 LSV
    2005 LSV - SOLD
    Jan 2010
    Milwaukee, Wi
    I run 15w-40 Amsoil Marine.
    08 Outback
    82 American Skier
    Oct 2007
    Panama City Florida
    Quote Originally Posted by phospher View Post
    You know any good synthetic oil would be a good choice. I suggest you pick the one that meets all of the required Indmar Specs and has the Bottle that appeals to you best!
    Jun 2009
    Newberg, Oregon
    I use mobil 5w-30 with a mobil filter. The mobil rep for the paper mill I do a lot of work at uses 5w-40 in his boat.
    Nate
    Sep 2005
    Claytor Lake, VA
    Check API ratings.
    From the manual:
    Indmar recommends 15W-40 Pennzoil Marine in their
    engines. If not available, use a 15W40 motor oil with an
    A.P.I. classification rating of SL/SJ/CI4/CH4/CG4 or
    equivilent. Synthetic oils are not recommended until after
    the engine has been run for 100 hours.
