Results 1 to 10 of 30
09-03-2010, 08:40 PM #1
I'd be interested in how to setup the flash drive if anyone has gotten that to work.
Thanks!Kraig - 2010 Outback V
09-06-2010, 08:49 PM #2
The USB port can only charge the Ipod. It sucks that you have to use two cables to charge the Ipod and listen to it through the radio. Wish they would have spent a little more money and installed the actuall MB Quart Ipod dock.
09-09-2010, 11:02 AM #3
Ok, I installed the MBQ-IPOD-HAR-13 cable last night for my IPOD. I can now control it through the stereo. The problem is where to put the cable. I too wish they would have just upgraded and put a docking station in the glove box with the USB port. I hate to drill any holes to run the cable through the glovebox. Maybe I can find a fitting of some sort if I have to drill a hole.
The sound quality of the IPOD cable is much better than the AUX input as well. Summer is over and buying a new boat at the end of the season is tough.
09-09-2010, 11:52 AM #4Senior Member
- Apr 2006
- Neely Henry, AL (live in Atlanta)
- 161
09-09-2010, 12:01 PM #5
I have a 8G nano video. I think it's about 3 yrs old. I plugged it in and worked great. I then ran the cable where I wanted it and it gave me fits. Bad connection or something. It would read it then give an error msg. It would then display the track but not the artist. I pulled the cable and hooked it back up and worked fine. It might have been pinched...The connection at the hard drive seems a little loose. Maybe it's a problem there. Tonight I'm going to shake and bend the cable a few times and see if the cable is faulty. It seems to work though (for the most part).
09-09-2010, 12:42 PM #6Senior Member
- Apr 2006
- 161
09-09-2010, 04:27 PM #7
I drilled a whole in the glove box and used a rubber grommet to make the whole look better. It works great having the iPod in the glove box.
