Thread: red light on throttle?
05-01-2010, 03:32 PM #1Senior Member
- Apr 2010
- saskatchewan, canada
- 334
When i start my boat the red light on the throttle comes on, why?
05-01-2010, 05:03 PM #2Senior Member
- Jun 2008
- NOR-CAL
- 178
is it at the base of your throttle ? If so it should be for the transmission . It will come on under 1500 rpm's I think it is ? It should go out when under way, But if it still stays on check your tranny !
05-02-2010, 07:03 AM #3Senior Member
- Sep 2005
- Claytor Lake, VA
- 599
It's the low oil pressure warning for the v-drive and should turn off above 1200 rpm. If it stays on, check the oil level in the v-drive. You can download an owners manual under community/downloads if you don't have one.
05-05-2010, 09:45 PM #4Senior Member
- Apr 2010
- 334
no problems light went off as soon as i put it in gear!
