Results 1 to 10 of 16
Thread: Trailer Brakes
    Sep 2008
    Port Byron, IL
    Default Trailer Brakes
    Are the trailer brakes activated when you apply the brakes on your vehicle? Does anyone run a brake controller on their tow vehicle? Anyone experience with and without, is there noticeable difference?
    Feb 2006
    Birmingham
    Your trailer should be equipped with surge breaks. The tongue of the trailer pushes against a master cylinder that applies the breaks automatically. The harder the vehicle tries to stop, the harder the breaks will be applied on the trailer. There is no controller in the vehicle. It is strictly a mechanical breaking system, the only electronics involved is the reverse lock out solenoid.
    15 Mondo Surf Edition
    02 LSV - Traded In
    Sep 2008
    Port Byron, IL
    Thanks! I guess I just assumed the brakes were electric. Nothing wrong with good old mechanical engineering.
    Henderson, NV
    I learned the hard way to always keep 2 nickels in the truck or boat at all times. if the reverse lockout fails or your electrical connection fails, you can use a nickel on either side of the tongue to defeat the lockout.
    had to do this a couple of times on a buddies truck that only had the 4wire harness
    Apr 2008
    California
    Correct on the key, if you have the UFP (Unique Functional Products) A-60 actuator like shown below. If you do have this actuator but don't have the key then call Boatmate Trailers and ask for one or you can also call UFP direct @ (760) 744-1610 and you can get one as well. They are located in San Marcos, California.
    I think I have the key somewhere but don't have this trailer anymore. If anybody needs it let me know.
    Oct 2008
    Central, Arkansas
    I would like to. I dont have it on my Boatmate.
    Eugene OR
    I also thought i did not have a key when i got my boat but it was wrapped in with a wiring harenst that came will all my paperwork. Just had to dig to find it.
    Quote Originally Posted by mcdye View Post
    Send me a PM with your address and I'll send it to you.
    Oct 2008
    Central, Arkansas
    you have mail..
