what is the tower diameter of the Rad a Cage.. i am looking to buy some accessories(racks) and i need to know the diameter and the boat is in storage.. anyone know for sure. thanks Brian
2002 MOBIUS LSV
Check out my post on 12-30-03. Go to seach, and under search text, type in tower diameter. The diameters for all of Skiers Choice towers are listed, hope this helps. If more info. is needed, please contact; [email protected]. Brian Raymond
You should check out the racks that Fluid Concepts make for that Radi-cage. They specificly fit the oval part of the tower. Mako also makes the same ones.
The tower should measure around 1 5/8" OD. Give or take. I had an issue with the Mako racks shifting on me. After several attempts to correct the problem, I found that sandwiching a piece of bicycle inner tube between the tower and the bushing solved it.
E.
