Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
  1. #11
    Dec 2015
    north texas
    Solid advice above. The stereo gets used pretty much entire time boat is in use. A good quality system will change the boating experience.
    2017 Supra SA
  2. #12
    Apr 2013
    Knoxville TN
    Check your stereo wire guage. I ran all new wire b/c the previous boat was a 2007. The tower was not that bad since the existing wires were in place.
    I also ran RGB wire for the add'l lights, speaker grills, and cup holders.
    2018 Supra SL400
  3. #13
    Aug 2017
    The tower is already wired with 16ga wires. I haven't look the space I have to rewire with larger gauge (and the work involved).
    BTW, for those of you that have the S-bend tower and used the factory mounting points, what spacer do I need? I've seen 1/2 inch. Is that exact ?
  4. #14
    Jan 2021
    Columbus, Ohio
    Quote Originally Posted by hguerard View Post
    Wish I could tell you but the Rev8 were installed when I purchased the boat.
    Exile makes mounts that fit the S-Bend but they are made specifically for Exile speakers. I'm sure they could be modified to fit another brand.
    Wet Sounds might have something similar but not on the website.
    2015 Moomba Mojo Surf Edition
    4,000lbs
    Manual Flow
Tags for this Thread
