Results 1 to 7 of 7
    May 2018
    Default Correct spark plug gap
    I'm replacing the AC Delco's with the NGK TR5 and am a little confused on the right gap for them. What would be the gap for a 2001 Indmar 350 with the carb. I thought it was .030 but I got information through Skidim that they are gapping at .045 so not real sure.
    Apr 2013
    Knoxville TN
    The 5.7 Pre Vortex is 0.035. MR43T
    The 5.7 Vortex Carb is 0.03. MR43LTS
    2018 Supra SL400
    Apr 2013
    Knoxville TN
    Those numbers came from an Indmar Spark Plug Chart.
    I did a screen capture b/c forget it.
    Probably can Google the same thing.
    It also lists the plug wires #s.
    2018 Supra SL400
    May 2018
    Thanks. It is a Vortec. I pulled a couple of plugs to check and they were gapped about .045. Has always run well though. Guess I'll do the new ones at .030.
    May 2018
    Plugs wear, especially the copper plugs you are referencing. Measuring used plugs is not an accurate indicator of what the gap should be.
    2021 Supra SA 400
    2018 Supra SA 400 (SOLD)
    Michigan
    Here you can find an interesting article about top 5 spark plugs for Vortec:
    https://autokwix.com/review/best-spa...gs-for-vortec/
    Sep 2005
    Claytor Lake, VA
    According to NGK the correct gap is 0.040".
    http://partcat.com/ngk
    2005 Mobius LSV
    325 EFI
