Results 1 to 10 of 20
    Sep 2015
    UT 6000'
    Default Ethanol free gas for car/truck
    Anybody use it and why? Just starting to do my homework to see what's the deal with it. It's grown in UT big time it seems.
    DFTR Josh
    Supra/Moomba
    www.marine-products.com (Discount Code: DFTR-1)
    Oct 2010
    Lake Wylie NC Area
    Ethanol is added to gasoline, so ethanol-free is, well, gasoline. Its gas prior to the corn lobbyist and environmentalists got involved with the EPA. Bottom line, there is ZERO good to consumers, about ethanol blended fuel.
    Sep 2015
    Conroe, TX
    If you can get it, run it. It's worth the $$. You'll most likely see lower fuel consumption, especially in a boat where the RPMs are higher at a constant load. Ethanol dilutes gasoline, takes more fuel to make the same sized bang in the cylinder. Pure gas will give more power with less fuel. (However, ethanol has a higher octane rating then gas. Pure ethanol is around 116 octane race fuel) Plus, ethanol and rubber do not mix. Eventually we'll all be replacing our fuel systems.
    Overkill is underrated
    2006 Supra 24SSV Gravity Games- traded but never forgotten
    2017 Supra SA 400
    Apr 2013
    Knoxville TN
    E-fuel will absorb moisture if you vehicle sits.
    Modern motors have internals that support the E-fuels. I keep it far away from my Chevelle motor.
    I’ve read about the better fuel consumption, but you have to offset the cost for those trying to save $$.
    2018 Supra SL400
    Sep 2015
    Conroe, TX
    The only part they can't make compliant is any rubber fuel lines. They have ethanol resistant rubber, but it too will rot away. There's a few companies in the go fast car world working on synthetic materials but not having much luck.
    And yes, thank you for mentioning the water absorption of the fuel... forgot about that for reason.
    2017 Supra SA 400
    Sep 2015
    UT 6000'
    Sorry if a dumb question: Do you need a flex fuel car to run E free gas?
    DFTR Josh
    Supra/Moomba
    Oct 2010
    Lake Wylie NC Area
    Quote Originally Posted by DFTR Josh View Post
    Not stupid at all. All gas cars and trucks can run E10 or even E15 pump gas. Then theres the good ol E85, which is 85% ethanol. You need a flex-fuel to run E85.
    Sep 2015
    Conroe, TX
    Yep, what MLA said. All a flex fuel car is, is a vehicle with a special sensor that can sense the amount of ethanol in the fuel. Since it takes more E85 to make the equivalent bang in the power stroke than just straight gas or a blend, it needs to know the amount so it can tell the injectors to fire longer.
    2017 Supra SA 400
    Sep 2015
    UT 6000'
    Getting gas in my wifes car I noticed the cap say E85/Gasoline, is that telling me it's actually a flex fuel car but don't say it with a fancy decal?
    DFTR Josh
    Supra/Moomba
    Oct 2010
    Lake Wylie NC Area
    Probably so.
