Page 1 of 3 123 LastLast
Results 1 to 10 of 28
    May 2013
    Vancouver WA
    Default Cutting 4" holes in fiberglass seat bases.
    So I've found that cutting 4" holes with a hole saw is a serious PITA. My 18v cordless drills get toasted in short order. I even bought a corded drill and found that I can smoke the motor on that one before I make much progress on the hole. I've got a couple more hot tubes I can add to my heater system but drilling the holes is literally a process that takes multiple sessions of drilling over a day or days. It doesn't seem like it should be this hard.
    What am I missing or doing wrong?
    www.TraysonsToybox.com
    Mar 2014
    Park City, Utah
    First, your inbox is full, second, what are you trying to do with the seat bases? Are you meaning the walls between the bottom of the seat to the floor? I had no issues drilling holes through my LSV, just never went 4".
    2017 Centurion Ri237
    2013 Supra SA450 - Sold
    2006 Mobius LSV - Sold
    2004 Stingray 190LS - Sold
    May 2013
    Vancouver WA
    Quote Originally Posted by sivs1 View Post
    Cleared inbox space.
    Yes, the walls between the bottom of the seats and the floor. Drilling 4" holes in them to add more Heatercraft Hot tubes. I have a 4 port heater that's located under the seat cushion that's behind the driver's seat (the one that folds up as a backrest). and I'm only using 2 of the hot tubes now and have a couple more to install! so need to drill 2 more 4" holes
    Oct 2010
    Lake Wylie NC Area
    I use 1/2" corded drill, so pretty stout. I also use commercial grade hole saws and arbor like De Walt or Lenox. Those cheap multi blade kits will dull by the end of the 1st hole, making more work on the drill and you.
    Henderson, NV
    ^this on the hole saws.
    I did 2 6" holes for added speakers in the tige seatbases. I went a bought a 6" hole saw at home depot. was somewhat expensive(iirc around $25), but my dewalt 18v cordless drill did both holes in short order and both were very clean with no de-burring necessary.
    sometimes right job=right tool....
    Never had an issue, I used a hole saw like that and my cordless drilled 13 2inch holes threw 2/4s no issues.
    I have not drilled 4inch hole in the boat, but I have drilled several holes one after the other.
    Personally I use reverse for only getting through the gell, once I am through that I switch it to forward and it eats like slicing butter.
    I am pretty sure I have that same kit you have from the HF.
    [COLOR="#696969"]
    I did three four in holes with my 18v Makita1/2 drill no swear, tapped and in reverse . Like butter.
    May 2013
    Vancouver WA
    I never had problems with 2" holes. From what I can tell the difference between a 2" and a 4" is 4x the amount of force needed, as the energy to radius ratio is the square of the increase in radius. so doubling the size of the hole is going to require 4x the amount of energy to turn it at the same rate. And I have to imagine there's a likewise increase in friction from having the circumference of the surface area the saw is encountering change.
    May 2013
    Vancouver WA
    Maybe it's just my cheap a$$ tired hole saw then... Because I tried 2 different 18v cordless drills and a 1/2" corded hammer drill as well...
    Mar 2003
    Springfield Missouri
    You should be able to see the condition of the teeth. Keep the drill speed at the highest speed and go slow.
    1998 Mobius
    310 HP PCM
    SOLD
