Results 11 to 20 of 24
  1. #11
    Mar 2012
    South Carolina
    Default Exile in the 2012 LSV
    ^^women just don't understand!
    Looks good keep the updates coming.
  2. #12
    If I'm working on the boat in the driveway and the volume knob goes over 20% Heidi is telling me to turn it down lol
    Sent from my iPhone
  3. #13
    Sent from my iPhone
    Claudia just comes out to dance in the garage or opens the door to the house. to hear our better. She knows there is no point to telling me to turn it down.
  4. #14
    Aug 2013
    DFW
    It's taken a while, but I finally got the sub (Xi 12D) and ZLD installed.
    I used uni​warking's box design, and it works great. My facade is different since I don't have the hump, but I was able to adapt. I used 3/4" birch for the box and facade. I coated each with 3-4 coats of spray on bed liner.
    The box is glued and screwed, then all of the seams are caulked.
    Matt
    2016 Mojo
    2012 LSV (sold)
  5. #15
    Aug 2013
    DFW
    Here it was when I was positioning it to get it under the helm. The base ends up 7" off of the floor to clear the cluster of stuff coming out of the floor. I had to move the main power wires and attach them close to where the air vent was attached to the wall. I also ended up letting the air vent hang loose. By the time it wraps around the box it doesn't have much slack left in it.
    I used legs to help hold the rear of the box up when I was screwing it to the facade, but I then ended up removing them because it wasn't needed, and trying to get each leg cut to the proper length was a pain.
    Matt
    2016 Mojo
    2012 LSV (sold)
  6. #16
    Aug 2013
    DFW
    Here it is after I had the box screwed to the facade. I was able to reach my arm and head in the box to caulk around that seam also.
    I later went back and cut the carpet around the hole to keep an air tight seal. I also put weather stripping around the sub.
    Matt
    2016 Mojo
    2012 LSV (sold)
  7. #17
    Aug 2013
    DFW
    All done.
    And the ZLD
    Matt
    2016 Mojo
    2012 LSV (sold)
  8. #18
    Looks real nice, but the subwoofer grill is on sideways.
  9. #19
    Aug 2013
    DFW
    Guess it is. I was matching the pattern to the one on the speaker. Maybe I'll change it
    Matt
    2016 Mojo
    2012 LSV (sold)
  10. #20
    Quote Originally Posted by Woody929 View Post
    If you like it thats what matters, just my 2 CU
