Results 1 to 10 of 13
Thread: winterizing
    Oct 2012
    Default winterizing
    how do you get antifreeze into outback v engine
    Jun 2010
    Lake Houston
    5 gallon bucket sitting on swim deck hooked up to fake lake is one way to do it
    2013 LSV
    2005 LSV - SOLD
    Jul 2011
    Central Wisconsin
    We remove the thermostat, take off the intake house, rig up a 5 gal bucket on top of the engine cover with a hose. Load up bucket with antifreeze, turn on boat, stick the hose from the bucket into the intake and let 10 gallons or so push through it. We forgot to drain the block first, but the antifreeze should have ran through it with all the antifreeze we put through it. Taking the thermostat out takes out the guessing work IMO, but I know plenty of people just get the boat to running temp.
    -Ryan
    twitter.com/WakeVideos
    2000 Mobius V
    Jul 2002
    London Ontario Canada
    Draining the block and the manifolds is the only sure way to know you have the water out of the engine and manifolds. You could then suck up the antifreeze thru the vdrive and that would get everything including the impeller.
    09 21v LAUNCH
    99 Outback LS. Sold
    Doug
    Apr 2011
    NY
    This is how I do it ('06 Outback): http://www.youtube.com/watch?v=UxmBD2wkk1I&feature=plcp
    '06 Outback - Gone but not forgotten
    '13 Mojo
    Nice work. How many gallons is really needed?
    There are two empty antifreeze containers on the ground at the 0:23 mark. Why I couldn't find any other empty containers that held a certain beverage is unknown.
    Aug 2007
    Alpine, Utah
    If you drain the water, why do you need the antifreeze?
    Garn
    2007 Mobius LS (Direct Drive)
    Aug 2011
    Quote Originally Posted by Garn View Post
    Just extra protection. If you have a heater or shower you need to do more than just drain it...
    2002 Moomba Mobius LSV - Sold
    2006 Moomba Mobius LSV
    Aug 2011
    Forgot to mention the ballast system..
