Results 1 to 9 of 9
    Jul 2011
    SE MI
    Default Blown Bass sounds from tower
    I have the stock Kicker system that came on the 2008 LSV (2 amps, a ZX200.4 that powers the 6 Kicker cabin speakers and a ZX250.2 that powers the 4 KM620.2 tower speakers) I was getting a blown bass sound from some of the tower speakers so I bought some replacement NOS KM620.2's and the system sounded great for 2 weeks... Now I am back to the blown bass sounds again and I am wondering whats going on... The stock system is fine for me and my family but I dont want to keep swapping out the tower speakers... Should I get a different (resonably priced) tower setup or can the speakers I have be repaired somehow? Is the ZX250.2 too much for these speakers? I am an audio novice so any help is appreciated...
    2008 LSV 1100s 650IBS Reversible Pumps w\Timers
    It's possible it's not enough amp and you're pushing it too hard. My 250.2 would barely power my two cheezy kenwood speakers on the tower. I swapped it out when I got my 4 Exile SXT's.
    Oct 2010
    Lake Wylie NC Area
    Sounds like the amps cross-over filter is set to "OFF". Needs to be "Hi-Pass". Check this before swapping any more gear.
    Jul 2011
    SE MI
    I checked the crossover switch and it was on HI but I switctched it to off & thrn back to HI in case it messed up somehow... Then I tuurned the bass boost down toabout 12:00 & I think the prob went away... I cranked the sytem as loud as I could in mydriveway & all good... Thanksfor the help!
    Nov 2009
    Stillwater, Oklahoma
    Bass boost on the tower amp should be totally off!!!!! Your high-pass crossover limits low frequencies, so having bass boost on is idisyncratic. One part of the amp turning the bass down and the other turning it up is not the way to run that amp.
    Where was bass boost on the tower amp set prior to your turning it to 12:00? It is probable that you found what was causing your speakkrs to sound bad.
    Again, turn bass boost totally off for the tower speakers.
    Phil
    Kicker
    Jul 2011
    SE MI
    It was at about 3:00! I bought the boat last year and I suspect the original owner had messed with the settings... Is there any documentation on all the original settings from the factory for 2008?
    Nov 2009
    I don't have setup sheets from then any more. Mine go back to 2010.
    In general for a tower amp:
    BASS BOOST Off
    CROSSOVER SWITCH Set to HI-PASS
    CROSSOVER FREQUENCY, (Hz) somewhere between 100 and 150
    GAIN I seem to recall for the old-old set up that the gain should be at ab out 11:00 as looked at as a clock dial...
    Does that help?
    Phil
    Kicker
    Jul 2011
    SE MI
    It sure does... Thank you... Can you suggest any settings for the in-boat speaker amp? Thanks for your help...
    Nov 2009
    Quote Originally Posted by eblom View Post
    Similar settings... with these exceptions:
    crossover set to 80-90
    Bass boost still set to off for the coax speaker amp channels
    If a subwoofer is in the boat, a litle bass boost is okay, but typically not more than about 10:00 as viewed as a clock dial... Subwoofer gain seems like it was at about 12:00
