I have a 2018 Supra SL I put the two 27D that comes with boat in parallel and on bank 1. Added another large 4D battery on bank 2. This is how I have done it with my Seadoo 18ft utopia and also my 2007 malibu 23 lsv. This is what’s needed for a stereo this powerful so you can listen for a long time and not drain battery.
I don’t think I left any electronics on and my bank 1 was dead. So started boat with bank 2.i think only the auto bilge is hard wired to battery. And I had no water in boat so don’t know what caused bank 1 to be dead unless I made a mistake and left battery switch on or if the alternator is broken,
When I started boat with bank 2, voltage level is 14 volts which should imply the alternator works. However after running boat I switched to bank 1 and ran above 3500 rpms for an hour and shut off boat and bank 1 was only at like 10 volts . So maybe it takes longer than an hour to charge a dead battery and I understand an alternator shouldn’t be used to charge a dead battery or could damage alternator.
I called Supra mechanic and was super disappointed . First off , all these boats have a popping noise thru audio when starting boat. Huge flaw and I know it’s caused by the huge voltage drop when starting these engines and they put in too small batteries . Mechanic called Supra and they said it was designed this way. So a $160k Boat was designed to give a huge pop to stereo ? What an idiotic response.
Then mechanic says Supra says only 27D can Be used and non AGM. I asked why and he says cause this boat is very sensitive to voltages. Another idiotic response. So we spend $160k on boats and this is the technical service we get ? They should explain the technical reason.
Since when does a boat not support AGM batteries ?
And as long as you are not using alternator to charge dead battery , there’s no reason you should not be able to use a battery larger than 27D. And if so then what’s the technical explanation ?
And the 4D resolves the audio popping issue which will eventually blow the speakers
Any one out there that had the knowledge to comment ?
Joe mama
