Hello,
How are you guys running speaker wire in your Oz towers? Upon first glance it seemed really easy, using the stock 2 holes drilled from the factory, run down the front side of the tower into the mounting bracket - but I just pulled the grommet and realized the place that is drilled does not connect to the front tower pole. Are you drilling through the front all the way through to the other side and then plugging it?
Thanks,
Dev
