Originally Posted by
2in2out
The GSA tab accessory creates a minimal yaw moment and delay in convergence through Bernoulli's Principle and Newton's 2nd law of motion in that the flow of water in the vanes increases in pressure and net velocity disrupting the laminar flow of the slip line of the hull creating delay in the convergence of the water. Imagine running a high volume pump and nozzle under the rear hull of your boat directed away from the surf side. Running a hose underwater doesn't create cavitation, whereas a tab penetrating the surface and disrupting surface tension does. The force of the volume of water emanating from the nozzle would alter the slip line subsurface, changing its trajectory creating a low pressure area where static water and the vectored water under pressure occur. Convergence shifts with less disruption to surface tension and amplified action.
Suck gates are more torturous in that they disrupt the surface tension and laminar flow so greatly that eddies and vortices introduce air into the slip line and convergence reducing the overall density of the wave, and as the Wake9 2021 Makai video shows, decreases the firmness of the wave. I would call this a forced convergence, because you're forcing the boat to disrupt its slip line to create a low pressure area for the opposing convergence to fill.
My concern with the Flow 3.0 tab is that it is to disruptive to the laminar flow of the slip line that it is introducing cavitation reducing wave density. I think the GSA design applied correctly on tab in which you could modulate the depth the chutes carve and redirect away from the slip line could give much greater wave adjustment.
The displacement created by a yawed hull is important in that it creates a larger low pressure area that increase in wave amplitude and the needs of surface tension are forced to react with a bigger wave. But if you introduce more yaw than can be absorbed by the slip line, laminar flow will be disrupted introducing cavitation and air induction at the surface. Add roll into the direction of yaw, and the laminar flow and resulting low pressure area are too subsurface for surface wave amplitude formation. One way to modulate yaw would be to include the tracking vanes and rudder into a complex system to force more yaw of the hull, but I have to think that beyond a certain percentage of yaw, significant drag would result and disruption of propulsive force of the prop.
The problem I see with ShoeBoxes set up is that the GSA like addition to the tabs forces water down and away from the subsurface convergence point as the down angle of the tabs is increased. An articulation point just forward of the vanes allowing them to ride parallel to the slip line, but subsurface may allow for better redirection at steeper tab angles. I wonder if putting a break and hinge forward of the GSA vanes and a gas strut for leveling of the GSA would keep it close to level but subsurface.
This is all great discussion. As a disclaimer, I have no engineering training and only minimal understanding of fluid dynamics. Everything I said I pulled out my arse to describe the vague and incomplete concepts of this whole thing out of my head. I understand why the patent stated "mythical".
