Thank you. When you say plastic side, is that the ballast side where the metal is mounted and the nuts go through to the engine side?
The metal goes engine side. Nuts go engine side.
Flat washers and round head or button head bolts go ballast side.
Nothing sharp against the bags....:cool:
Bolt example.
Attachment 29968
I replaced the pre o2 sensor on the starboard side and it solved the problem. The bag was indeed encroaching in the engine area and the O2 sensor was being impacted.
