There is always a consequence to exceeding a boats max payload. Premature engine and drivetrain life.
No different that exceeding a trucks tow capacity, will it pull overloaded? Sure, but for how long.
Probably not apples to apples on this comparison.
I think before you start wrecking mechanicals, the boat simply will not get to speed. I don’t think you’re going to grenade a motor or tranny running overloaded. It simply won’t pull it.....?
I am sure you will disagree with me, as per forum dynamics, but I have not heard of premature driveline failure in a surf boat due to heavy loads.
Maybe someone has.
Max capacity ratings are not correlated with driveline wear limits as far as I know. They’re correlated with the hull’s ability to float the weight safely, no?
If the former were true, the 575 boats would have higher ratings than the 400 boats.
I didn’t take pics, unfortunately, but do I have expensive taste coming from the big mama pump SE.
I was impressed. ESPECIALLY in 11’ of water. Something I would typically avoid!
11.4 I think. Autowake ON. Pitch at 8.5 degrees and roll at 4 degrees, amplitude 100. People moving everywhere, pumps running all directions....just sweet.
Well I guess you did spill the beans ... the tube/sensor will have a wireless connection ... which is where a lot of things are going if they aren’t truly required to be failsafe ...
Well on 2nd thought maybe not ... you’re running the sensor between bag and pump so if sensor indicates that bag is full then pump stops ... whatever you put in between the reversible pump as a switch will do ... same concept as you have on the touch screen and the manual switches ... in an home you would call it a 3way switch I guess ...
This is for goose:
Regarding full bag sensors. With the 2018 auto wake equipped boat the computer doesn’t really care how much ballast is in each bag, is this right? It will continue to pump in or pump out in the appropriate spots in order to satisfy its sensors I assume. In other words when a ballast bag that is on timers reaches “100%“ does auto wake stop trying to fill that bag?
Fast forward to 2019 and bags with sensors. I would think this offers an advantage from the standpoint that once the bag is ful—auto awake will stop trying to fill it; and if it’s sensors are not satisfied yet at that point, it will tell you to move people. Because no ballast is available to affect running attitude.
What does the 2018 boat do in this scenario? What if you had your ballast timer set super long? Would it just pump water overboard trying to fill a bag that is already full in order to satisfy a sensor?
Except that prop is the one thing you can’t control ... I’m the perfect example for that. Ordered the SL400with the 2277 prop because it worked well in my 2017 Malibu 23LSV ... except that the SL has a 1.5:1 tranny and not the 1.76 ... call me stupid because I was ...
So you would need to know pretty much every prop combination and test it to tell if the boat can do it or not ...
I learned the lesson quickly as nothing was happening when loaded up so got a different prop ... and it runs fine since. But with 5 people, 4 dogs and the additional 800 lbs of ballast the engine is running at 3800 to 4000 to push the weight ... and the wave is marginally better ... snot like your getting another 10 feet to play ... maybe 1 or 2 ...
As said before by others ... there’s only so much the boat can displace effectively regardless of engine ... except you consider a submarine a great surfboat [emoji12]
