evidently i dont have enough posts on here so they wont let me post pics?
http://uploads.tapatalk-cdn.com/2016...bf01bcdd0d.jpg
Sent from my SM-G930R4 using Tapatalk
Great idea after doing some research I might have one made like the one below. My buddy has the Malibu plastic tray and it works great except for being shallow. Think you might be able to make it deeper to hold a few life vests.
Engine Storage Tray Make out of Aluminum
http://www.themalibucrew.com/index.p...za-pan/&page=2
http://uploads.tapatalk-cdn.com/2016...fe608f2ec1.jpg
http://uploads.tapatalk-cdn.com/2016...47ed1d1a72.jpg
That looks like it's a disaster waiting to happen... Take a look at the motor right around that white dangling rope. See all the turning parts?
I spent 75$ on the 1/2" board and 15$ on aluminum angles. drilled two holes in the back corners for water too go out. this adds alot of space!
Okay, based on your idea I went and built one for myself. I only had the depth for mine to be 2 1/2" for most of it, tapering to 3" towards the bow. I used 1/4" HDPE to keep the costs down. About $10 in aluminum angle and $60 for the two sheets of 24x36 HDPE. I already had the stainless screws.
I don't have a front or back wall on my "tray" because they go flush against the walls of the engine compartment. The rear tray has a piece of hdpe under the bottom to form a lip so the floor of the forward tray dovetails against the floor of the rear tray. Because there's no forward or rear walls, there was no need to cut out for the shock mount. only cut the floor out around the ski pylon. and the floor actually rests on the big nut for the engine compartment lid latch.
Because my HDPE was 1/4", it was more susecptible to not having the sides to floor square, so I used some of the angle to reenforce the right angle of the floor to side wall junction. Likewise, because my HDPE was only 1/4" thick, I used my air grinder to hack off the tips of the screws that were poking through the HDPE.
Lastly, on the front tray, I put some nylon webbing along the sides to form a pair of "handles" so I had something to grip when I wanted to remove the front tray. The front tray comes out first, then the rear.
Mine is deep enough to fit ropes or even the throw cushion. All in all a nice upgrade.
Webbing "handle":
http://i1070.photobucket.com/albums/...pshqnwrlu9.jpg
http://i1070.photobucket.com/albums/...psu93ouxsi.jpg
http://i1070.photobucket.com/albums/...ps7cgyadyb.jpg
The shadow makes it look like there's a hole under the latch against the pylon, but the hdpe snugs right up against that latch. unless something was the size of spare change, it's not going to fall through into the engine compartment.
http://i1070.photobucket.com/albums/...psuuuceoqg.jpg
Looks great Trayson! Gotta love more storage
Trayson, does the cover on the XLV have a recessed area in it? On my LSV, there is a little recessed box just aft of the pylon. I assume that it is there to allow clearance with something in the engine bay but I haven't really looked that closely.
No, it doesn't. it's completely flat aside from the hardware sticking out from it for the latch on the handle. You can barely see it in this picture:
Maybe your boat had the hardware removed for the latching mechanism on that engine cover?
If it makes a difference, I have the 340 CAT engine.
Since I use both back ballast bags when surfing, I'm looking for room.
I could see throwing dock lines, bumpers, wake ropes, extra life vests or throw cushions, etc.
Good idea.
I don't have as much clearance on my XLV with the 340 CAT engine. I was able to get 2.5" rear and 3" of depth in the front. For me, the limiting factors were the top of the wakeplate hydraulic reservoir, the metal tubes coming off the O2 sensors on my exhaust risers, and even the top of the intake manifold itself. The newer boats obviously have deeper lockers for the engine and v-drive lockers.
But it's deep enough I can fit lines, handles, throw cusion; and hopefully some leftover pizza.
I would love to do this on my 07 LSV but with the plastic hood over the engine there is no room at all. The back 1/3 maybe has some room but there is no way to cover the whole engine compartment. I guess I could take the hood off, it really isn't anything that needs to be there right?
