I wouldn't have thought you would have a breaker on the dash panel. Exposed to the environment or direct water with no cover?
Not that I am familiar with these boats (yet).
well its got a rubber cover over it
That sounds odd but at least it's protected.
05's don't have check engine lights that I know of. Started in 06
This really sounds like an Ignition Control Module problem. I really don't know off hand if the engine has one of these. I know on older small blocks this was an issue when the module gets hot its internally shorts and kills the engine. Then it cools off a bit and works again. I chased this issue on my Vette. It looks like this and they are in the distributor or mounted outside. When mounted outside it has a 4 wire plug if i recall, and will be mounted to some kind of heat sink. I had a 92 Z28 with one in the distributor and the contacts where corroded so it would run great when the car sat a while, then once it got hot and began to cool off say at the gas station it would crank with no start.
http://www.ebay.com/itm/like/2314390...lpid=82&chn=ps
X2 for Mike. I've replaced the electronic ignition on my 98 twice and in both cases the engine was very unpredictable but it continued to run
Bypass the oil pressure switch, not the oil pressure gauge sensor.
