Ok, reviving this as we start to get close (a few months away) to my season up here….
A bit of a read but want to give as much info as possible….
I was really excited about the even larger Makai bags from WM, but, as they are still in production/development, and some soul searching over losing the additional storage space, plus the fact I have upgraded my tow vehicle… so I have pivoted a little and would be interested in hearing some advice about setups…
I have purchased a set of the upgraded WM bags, so there is the additional close to 700lbs of potential there… am working on accumulating the parts to create the venting system as many have done, as well as additional engine panel reinforcements (am working on a bit of a creative solution I will share as it comes to fruition)
Now… we did found during winterization that the centre bags were not emptying fully, and we suspect that may have also led to them not filling properly, my dealer lifted the front of the boat to fully drain, the impellers seem to be the issue, but we will not fully know until we do a lake test (more on that below)
I typically run a very small crew (myself and 5 others estimated about 750lbs), and while everyone was surfing, it surely needs optimizing with this size of a boat… I have been watching and rewatching a lot of the Wake9 stuff, and that has been so much more enlightening after having a half season on the Makai, I know understand the dynamics to the point where I feel I could make some decisions/guesses/estimations about where I need to be…
The lakes I am at the majority (90 percent) of the time are between 1000 and 1300 feet elevation….
Ok, now onto the fun stuff…
I am looking to also supplement the WM bags with lead…. Once we can we are going to lake test the boat with a lot of lead with my dealer (who has been awesome through this), but wanted to do a base setup beforehand….
First ensuring all existing bags do fill fully, so rectifying the issue with the centre bags
I was going to add 200-250lbs in each rear corner, right under the WM bags to start… who has done this? Any feedback….
Then manipulate as much lead as we need to hit the Wake9 determined settings of pitch and roll while also achieving max displacement by:
Adding lead in the storage lockers on either side ahead of the bags, adding lead to the centre of the boat (going under the track can compartment beside the batteries), and also in the very front locker of the boat…
I know some of you are using the WM bags with 1000lbs or more of lead, but your setups on board may be a bit different so I welcome any and all feedback about where you ended up and how you got there (yes I know this has been hashed and rehashed in many other threads and posts, and I have searched all my way through most if not all of them), but what a better way to spend the last days of winter right?
I was guessing I would be at:
WM Bags additional 700 (345 per side)
Under rear bags additional 500 (250 per side)
Ahead of rear bags 200 (100 per side)
Centre near batteries 300
Front bow locker 300
So about 2k more than ‘stock’…. And adjusting as/if required on the lake test….
Thoughts?
