5 Attachment(s)
Rudder seal replacement...new style without grease zerk
Alright guys,
Many have been talking to me about topics and I chime in trying to help where I can. Many of you have helped me already and hopefully this helps someone else.
First, be thanks to SEF for sending me o-rings for this job, but they could be found elsewhere. I posted the dimensions in another thread.
Secondly, it appears the rudder port box is common among a large amount of rudders from SC. I verified my part number through my dealer for the whole rudder kit (115203). Newer boats use 117072 but the port box is the same.
First off, make sure your bags are empty before pulling them out. Mine still had 10-12 gallons and made a nice pool for me to work in. Only have to pull the port bag but I pulled both engine dividers for my shop light.
Attachment 29822
Next, I was lucky enough last outing to get the boat on the trailer far enough forward to remove the rudder. You could let it hang 4" back to accomplish the same thing. I have seen jacking the hull to clear also, but I never had a problem.
The hardest part is the SS cotter pin. There is no room to work and it does not want to be straight again. Once I donated blood to the mechanic gods it came right out.
Attachment 29821
Once removed, te nut and bolt for the tiller arm is straight forward. They are stainless and non-magnetic, DO NOT DROP THEM.
Attachment 29823
The tiller arm will release and the rudder will fall pretty easy once the boltnis removed. My dad came over to help and held the rudder and lowered slowly while I made surebthe tiller arm and key stock didn't fall under the engine. Once secured, he turned the rudder and pulled right out.
Port box only has 1 O-Ring at the top. The rest is sleeved with a carbon liner (yes $0.50 o-ring = sunk $80k boat), I was shocked also.
Attachment 29824
Attachment 29825
