I am away fro the boat and need to order plugs. Can anyone help? 2000 Outback with 310 HP Carb (Indmar 350)
Yep! I'm pretty sure you will need some. Mine won't run without them.:p
The plugs needed are a AC brand MR43LTS. This is OEM equipment, which are not offered at automotive stores, and should stay that way. These plugs are only available thru a local dealer or Indmar. The MR verifies it is a marine plug, and that the threaded part is stainless, (to ease removal and life of the plug in such a moist environment.). The gap should be.028 on carb. motors, and .045 on the fuel inj. motors. Hope this helps. Brian Raymond
