Results 141 to 150 of 158
Thread: 2016 Mojo Updates
05-11-2016, 01:47 AM #141Member
- Sep 2015
- 77
KG,
what wires did you use and where did you get them?
Power, ground, speaker, RCA?
Distribution blocks?2016 Mojo (HERE!!!!!)
2007 Supra Launch 22 SSV Limited
1990 MasterCraft Tri Star
1997 Crownline 180BR
05-11-2016, 09:12 AM #142
I used factory speaker wiring and order all other wiring (power/ground/rca) from knuconceptz. On the distribution blocks, it was tspec from amazon.
2016 Moomba Mojo
2006 Supra 24SSV - Traded
05-11-2016, 11:10 AM #143
According to their website the 8 gauge wire is only good for 60 amps. I am running an 8 gauge wire to my distribution block that sends power to my 3 reversible ballast pumps and each pump draws 30 amps so I guess I am not running a big enough cable since 3x30 =90 amps draw when all three pumps are on. I guess I need to see if I can run 4 gauge to my ballast pump distribution block.
Could this be why whenever I turn on more than 1 pump and there is a noticeable drop in the sound the pumps make? Like with one pump, it sounds like that pump is screaming and moving fast, when I hit a 2nd pump, you can hear it come on, but it sounds like both pumps are running slower than one pump by itself and when I hit a 3rd pump on, they all 3 move so slow that it is almost silent.David
05-11-2016, 11:25 AM #144Malo <--- Means--Evil or Mean One. This explains a lot.
[COLOR="#696969"]
05-11-2016, 11:29 AM #145
Yeah I have 8 gauge going to a blue seas distribution block, and then 12 gauge that was supplied with the wakemakers kit going from the distribution block, to the switches, then from the switches to the pumps. The distribution block has a 30 amp fuse for each pump. As you turn more pumps on at the same there is a huge audible reduction in pump speed. Very noticeable. Maybe it is the type of impeller I am running? I have found that after sitting for a few weeks they have a tendency to get stuck and I have to work the switch back and for a bit to get the pump to do anything.
05-11-2016, 11:34 AM #146
I think your theory sounds plausible. just because a single pump is wired with a smaller gauge doesn't mean that the gauge for the longer run to the distro block shouldn't be more. It's not like 4 gauge is THAT expensive. You've got audible hints and also you've done the math that backs it up. I'd say you've got enough "evidence" to support your theory and you know the "fix".
*** That said, I would check your stats on amp draw. I'm thinking more like 20 amps, but that they're fused with 25 to 30 amp fuses? Either way, you can certainly compute the length of your run of wire to your distro and compute the voltage drop and see if that is likely to be affecting you, even at a ~20 amp draw.Last edited by trayson; 05-11-2016 at 11:42 AM.
www.TraysonsToybox.com
05-11-2016, 12:19 PM #147
The wire run is going to be shortened when I get home. I have a bunch of extra 8 gauge coiled up because i already had my connectors on the ends and I did not have any more connectors to cut the wire and add a new connector but I have since got some in. I will be shortening it by 2/3 or so so that may help. If that doesn't work then I may look into 4 gauge going from the battery to the distribution block and possible going from the black implellers to the green ones everyone raves about.
05-11-2016, 12:29 PM #1482008 Moomba Mobius XLV. Monster Cargo Bimini, WS Rev 410's, Polk Cabins, 3 Infinity Subs, PPI amps, WS420, Exile BT, upgraded ballast pumps, up to 3,500+ pounds of ballast, Blue LED's...
06-06-2016, 09:56 PM #149Senior Member
- Feb 2016
- 158
06-06-2016, 10:14 PM #150
