Page 1 of 18 12311 ... LastLast
Results 1 to 10 of 177
    Dec 2018
    Dublin, Ohio
    Default May 2019 Pic Thread
    Ceramic coating done on the Craz! Even though it only had 9 hours on it the polish really fixed some issues that dealer prep didn’t catch. Looks mint now!
    Also got first oil change done yesterday, used the strainer/flush kit to warm it up...loooove heading this run out of the water
    2019 Craz
    Feb 2018
    Boating on Lake Martin, AL
    Looks nice and shiny! I am probably going to try F11 on my boat, which I should finally be able to participate in these monthly threads hopefully soon
    I plan to get the strainer/flush kit as well. I should have just added it on the build. Is yours the same one they use or did you use another companies strainer?
    2019 Moomba Max "MOOMBAE"
    2016 Yamaha AR192 - sold
    May 2018
    Quote Originally Posted by Matt0520 View Post
    Looks OUTSTANDING!!!
    What ceramic did you use? I am applying IGL Marine as soon as weather is 60f+
    Fully polished with Rupes UHS and carpro Essence and ready for Ceramic
    2021 Supra SA 400
    2018 Supra SA 400 (SOLD)
    Michigan
    Mar 2017
    Middle TN
    Does everyone use transom straps when towing? Seems like it would put alot of stress on the platform. I'm assuming bc of the wake plates that there is not another tie down option?
    Henderson, NV
    Quote Originally Posted by Surgical_ass View Post
    was thinking the same thing on this install. the way those transom straps are installed- and I'm no physics dude but do remember a tad bit from school- that mounting point on the platform looks like it would add a lot of stresses to the swim platform mounts on the hull of the boat from the distance out.
    kinda get a feeling with all the crap they add to the transoms of these new surf boats(and skiers is def. not the only one) that the transom straps are becoming more of an afterthought. my current boat is the same way.
    May 2018
    Transom straps work great, cinch them down just enough to take slack out.
    Easy peasy.
    2021 Supra SA 400
    Michigan
    Henderson, NV
    Easy peasy.
    agreed, it's the location on the platform that is the question. most transom straps I have seen/used hook to the lifting eyes as that's what they are designed/engineered for. all the surf stuffs hanging on the back of the boats is making that increasingly difficult and wonder if the swim platform brackets have been engineered to withstand the forces needed.
    May 2018
    The platform is designed to take 300# with safety factor, I don’t see exceeding that with straps unless you over ratchet them.
    2021 Supra SA 400
    Michigan
    Mar 2017
    Middle TN
    My concern would be a pot hole that causes the boat to bounce. I also don't know the physics numbers so there may be more force at a different point on the trailer and the transom straps are fine attached to the platform.
    Feb 2018
    You don't have to cinch them down super tight. Just snug so that the rear of the boat doesn't bounce if you do hit a pot hole or have to make an evasive maneuver. I'd rather have my swim platform take any damage than let my hull bounce around on the bunks.
    After taking the tour of the plant this week and seeing the material that is used under the swim platform I have no worries. The transom is also heavily reinforced where anything mounts to it.
