Page 2 of 9 FirstFirst 1234 ... LastLast
Results 11 to 20 of 83
    Jan 2021
    Columbus, Ohio
    I bet that will work better than you expect.
    My only issue doing the trans cover is if the adhesive does not hold well from moisture and/or heat and falls off. It basically lands on the prop shaft coupler of the V-drive and shreds apart or wraps around the shaft and causes damage. I know the dynamat type stuff is bonded and not coming off.
    2015 Moomba Mojo Surf Edition
    4,000lbs
    Manual Flow
    May 2018
    Good point, but if this is typical closed or open cell foam, I don’t see it taking out a prop shaft, but it could make a shredded mess.
    I will try it on trans hatch and put a heat gun to it and see if adhesive fails.
    2021 Supra SA 400
    2018 Supra SA 400 (SOLD)
    Michigan
    Jan 2021
    Columbus, Ohio
    Let us all know what you find out. The dynamat material did help with vibration created noises and removed some of the higher pitch whine. I would be willing to throw $50 at something that will take it down another notch.
    4,000lbs
    Manual Flow
    May 2018
    Of course, I was only waiting to see what Supra ended up using.
    I should also have a couple more fall cruises to do an ear test before storage.
    2021 Supra SA 400
    Michigan
    Apr 2013
    Knoxville TN
    I'm going to find out too.
    2018 Supra SL400
    May 2018
    Foam showed up, started on trans cover.
    2021 Supra SA 400
    Michigan
    Jan 2021
    Columbus, Ohio
    Between that new foam and the surf pipe, should be nice and silent for surfing and music blasting.
    You going out on the lake to test it this weekend?
    4,000lbs
    Manual Flow
    May 2018
    I hope to.
    2021 Supra SA 400
    Michigan
    Mar 2021
    South Georgia
    WOW! If that glue holds up, that has GOT to make a difference! Looks good too. People are gonna think you have an electric powered boat!
    2021 Moomba Makai
    May 2018
    Default 2022 Sound Proofing
    Main floor
    2021 Supra SA 400
    Michigan
